sh ip cef
vsabariraja
What are different types of entries and their meaning in the "Next hop" field from the "sh ip cef" command
Julio Carvajal
Hello Sabari,
Prefix: The longest match for a specific subnet or IP address. ( Could be a host or a network, this is what makes the difference from the routing table and the forwarding information table because you seldom see host Ip's on the routing table unless configured or advertised) This will provide a better performance at the time to do a route lookup.
Next hop:  1-Attached: Directly connected
                2- x.x.x.x : Ip address of the next hop Ip address
                3-Receive: No next hop defined so need to be sent to the Router Engine (RE) for further lookup
Hope this could help
Julio
Remember to rate all the helpful posts
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Reza Sharifi
Have a look at the command reference guide, it has explanation for each keyword:
http://www.cisco.com/en/US/docs/ios/12_3/switch/command/reference/swi_s2.html#wp1076661
Julio Carvajal
Hello Sabari,
Julio
Julio
Julio Carvajal
