sh vlans vs sh vlan-switch
I'm playing with my Cisco 892W router and just figured out that if you create a VLAN the only way to show the vlan information is via "sh vlan-switch" command. If so what is "sh vlans" command do? On the router for "sh vlans" it says no VLANS has been configured.
Thanks in advance,
cadet alain
sh vlan-switch is the command for routers with a ethernet switch module either integrated or added to the router.
sh vlan is for switches.
Regards.
Alain
cadet alain
Regards.
Alain
That make sense - cheers for clarifiying that.
