SHA 256 enable password on 6509 and 4500
CATYO
Hello.
I just want to know how to configure SHA256 of enable password on 6509/4500. and which IOS version supports it??
I tried to find out but i couldn't .
Sorry for this easy question. : (
My 4500 is running with 15.2(Catalyst 4500 L3 Switch  Software (cat4500e-IPBASEK9-M), Version 15.2(3)E, RELEASE SOFTWARE (fc4))
and when i typed ' enable secret ?'
(config)#enable secret ?
  0      Specifies an UNENCRYPTED password will follow
  5      Specifies a MD5 HASHED secret will follow
  8      Specifies a PBKDF2 HASHED secret will follow
  9      Specifies a SCRYPT HASHED secret will follow
  LINE   The UNENCRYPTED (cleartext) 'enable' secret
  level  Set exec level password
there is no type 4.
But when i create user account, it looks support.
(config)#username test algorithm-type ?
  md5     Encode the password using the MD5 algorithm
  scrypt  Encode the password using the SCRYPT hashing algorithm
  sha256  Encode the password using the PBKDF2 hashing algorithm
What's wrong ?
Thank you in advance : )
Reza Sharifi
Here is how to configure it and the version that supports it:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/security/d1/sec-d1-cr-book/sec-cr-e1.html#wp4278835710
enable algorithm-type { md5 | scrypt | sha256 }
Thank you for your prompt reply.
I checked it and it says
15.0(1)S
This command was integrated into Cisco IOS Release 15.0(1)S. Support for the type 4 algorithm was added.
But my c2900 with c2900-universalk9-mz.SPA.152-4.M7.bin doesn't have type 4 command.
  R1(config)#enable secret ?
What seems to be the problem ? T.T
You absolutely do not want to use a type 4 password.  Use something like the below.  It's not SHA256 - it is better.  SHA256 is used to test if something has been tampered with - which is not really want you want for a password hash.  scrypt is far more suitable.
enable algorithm-type scrypt secret <password>
