Shortcuts for Creating VLAN
naveen.bodhula1
Is there is any shortcuts for creating VLAN for number of ports at a time.
Not like this:
int fa0/1
switchport mode access
switchport access vlan 10
int fa0/2
int fa0/3
So I want to give interfaces 1,2,3 to vlan 10 with only one command.
TIA
6 Replies 6
Mark Malone
Hi Naveen
yes you can use the range command
interface range g0/1 - 24
switchport access vlan 2
Thanks fro the reply
Is 'switchport mode access' is mandatory  command. Even if we didn't execute it, the vlans are creating, then what is the purpose of it?
Hi ports are dynamic desirable on certain platforms by default , this command prevents it ever trying to negotiate or be anything like a trunk ., its best practice to assign it as access so it always behaves that way if its going to be an access port
And what is the shortcut if I wanted to assign same VLAN to port numbers such as 1,3,5,7 with single command?
 the range command is how you do all interfaces , you can use just the switchport access vlan x command it will work fine but if you want to do best practice by Cisco use the 2 commands above , that's as short as it gets in terms of syntax , it just means if you use the one command and someone disconnects your pc and sticks in a switch it may forma trunk depending so for security ad best practice you use the 2 commands
Whenever a port is access like pc or printer etc connected you should always use spanning-tree portfast and spanning-tree bpduguard under your access ports as well another best practice
johnlloyd_13
Level 9
Level 9
hi,
you can do this:
int range f0/1-3
switchport host
