Should 3845 gigabit interface show down/down or up/down when no cable is connected?
CHRISTINE BERNS
We have a number of 3845 routers, some running IOS 12.4(22)T2 and earlier and some running 12.4(24)T4.  On the ones with 12.4(22)T2 and earlier, gigabit interface g0/1 shows interface down/line protocol down when there is no cable connected to the interface and the interface is not in shutdown state.  On the ones with 12.4(24)T4, gigabit interface g0/1 shows interface up/line protocol down when there is no cable connected to the interface and the interface is not in shutdown state.  Interestingly in both cases, the "show controller g0/1" command shows " network link is down (NO CARRIER)" when there is no cable attached.  It makes sense to us that the interface status would be down/down when there is no cable attached.  It does not makes sense to us that the interace would be up/down.  Did Cisco at some point change their philosophy on whether an interface should show down/down or up/down when there is no cable attached, or is this a bug?
Leo Laohoo
Could be an IOS bug.
