show bootflash output doesn't display space occupied by IOS image
rizwan shaikh
Hello All,
We are having Cisco 4948E model switches.on one of switches while troubleshooting high cpu I have noticed that show bootflash doesn't show any IOS statistics like total or free space!!
Can anyone give any advice on our future course of action
11 Replies 11
Reza Sharifi
What is the output of  sh flash or dir flash?
Switch#show bootflash:
 Error in reading FlashDriverCompactstarting at sector 286
 Aborting read operation
%Error show bootflash: (No such file or directory)
Also see show version commands partial output:
show ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M),        Version 12.2(54)XO, RELEASE SOFTWARE (fc1)
System image file is "bootflash:/cat4500e-entservicesk9-mz.122-54.XO.bin"
Also i am getting lots of log as below.
Feb 20 2015 12:41:52.686: %C4K_SWITCHINGENGINEMAN-4-TCAMINTERRUPT: flCam0  aPErr interrupt. errAddr: 0xB2B dPErr: 1 mPErr: 0 valid: 1
Feb 20 2015 12:41:52.686: %C4K_L3HWFORWARDING-4-FLTCAMPARITYERROR: FL Tcam Perr with no FwdEntry Hw index: 2858 Hw entry:  Sw entry:
Feb 20 2015 12:41:52.686: %C4K_FLASH-4-COMPACTFLASHNOTREADY: Compact flash is not ready
Also cpu utilization is really high from last 3 days
CPU utilization for five seconds: 99%/0%; one minute: 99%; five minutes: 99%
 PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  78   8081613301072221334        753 93.76% 83.35% 80.65%   0 GaliosObflFilesy
  59  36472656262967331930          0  4.14% 12.00% 14.11%   0 Cat4k Mgmt HiPri
Also see o/p from show file system
show file sys
 Error in reading FlashDriverCompactstarting at sector 56
File Systems:
     Size(b)     Free(b)      Type  Flags  Prefixes
  128282624           0     flash     rw   bootflash:
           -           -      disk     rw   slot0:
           -           -    opaque     rw   system:
           -           -    opaque     rw   tmpsys:
           -           -    opaque     ro   crashinfo:
      524284      523548     flash     rw   cat4000_flash:
           -           -    opaque     rw   null:
           -           -    opaque     ro   tar:
           -           -   network     rw   tftp:
           -           -    opaque     ro   profiler:
           -           -    opaque     wo   syslog:
      524284      515146     nvram     rw   nvram:
           -           -   network     rw   rcp:
           -           -   network     rw   http:
           -           -   network     rw   ftp:
           -           -   network     rw   scp:
           -           -   network     rw   https:
           -           -    opaque     ro   cns:
Hi rizwan shaikh! I Have the same problem too but with WS-C4506-E.
Have you solved the problem ? How ?
Thank you.
Post the complete output to the command "sh proc cpu sort | ex 0.00".
I dont have access to switch right now. Its our customer.
show process cpu and sh cpu history in attach
Thanks for the attachment.  I want to wait until you get access and run the command requested.  :)
Dear Riswan,
This is usually due some bad sectors at bootflash. You could try reloading the switch to see if it clears it. But it has a risk associated since the switch may not bootup if it is hardware issue. Also you are seeing lot of parity errors also which gives some evidences of hardware issue.  So please be prepared with a spare switch if you try to reload, since you may need to replace the unit if it fails after reload.
Hope this help.
PS : Kindly rate all useful posts
Madhu
