We are facing high cpu utilization issue in our core cisco 3750x switch.
We would like to know what might be causing the issue.
attaching the logs for the issue. Can someone help on this.
The most stable IOS for the 3650X/3750X is 12(55)SE10.
Hi Leo,
Thanks for reply.
We have upgraded to version c3750e-universalk9-mz.150-2.SE7.bin but even after upgrade we are facing same issue.
Any abnormalities you found in log..??
Thanks in advance.
I repeat: The most stable IOS for the 3650X/3750X is 12(55)SE10.
I did not see anything useful with the files attached.
