show interface trunk and n-isl
hanwucisco
Could you tell me that is n-isl under the show command?
this came when two sides are in default setting. once i configured encapsulation to isl, it changed to isl.
What is difference between isl and n-isl?
thanks,
Han
5 Replies 5
Jon Marshall
The n in n-isl means negotiated. So basically the switches at either end negotiated to ISL encapsulation for the trunk link.
Once you hardcoded the encapsulation there was no need to negotiate so then the n disappeared.
Jon
Jon,
I tried on two 3750s. it seems that it is different from what you said. any idea?
thanks,
Han
What do you mean by "it is different". What behaviour did you see ?
Jon
Hi, as Jon has stated - the trunk is either
n-isl / n-dot1q = negociated
or
isl / dot1q =full trunk mode
for N-ISL/dot1q to happen you need one of the trunk links to be in a negociated stated - like
switchport trunk encap ISL /dot1q
switchport mode dyanmic desirable/auto
hardcoding the trunk would be
switchport mode trunk
res
Paul
Kind Regards
Paul
gcmills
Default negotiation for 3750's is dot1q. That's why you see the difference between your first and second post.
