Show interfaces Transceiver not displaying detail on a 4500
Steve Wood
When  I run "sh interfaces transceiver" on a 4500 it fails to display any details. SFP modules fitted are GLC-LH-SMD=. When swapped into a 3750X "sh interfaces transceiver" works fine. Anyone resolved this issue ?
sh module
Chassis Type : WS-C4510R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
 1    48  10/100/1000BaseT Premium POE E Series  WS-X4748-RJ45V+E
 2    48  10/100/1000BaseT Premium POE E Series  WS-X4748-RJ45V+E
 3    48  10/100/1000BaseT Premium POE E Series  WS-X4748-RJ45V+E
 4    12  1000BaseX SFP                          WS-X4712-SFP-E
 5     4  Sup 7-E 10GE (SFP+), 1000BaseX (SFP)   WS-X45-SUP7-E
 6     4  Sup 7-E 10GE (SFP+), 1000BaseX (SFP)   WS-X45-SUP7-E
 7    12  1000BaseX SFP                          WS-X4712-SFP-E
 M MAC addresses                    Hw  Fw           Sw               Status
 1 6412.25fe.f740 to 6412.25fe.f76f 1.5                               Ok
 2 1005.ca82.5540 to 1005.ca82.556f 1.5                               Ok
 3 7426.ac47.eed8 to 7426.ac47.ef07 1.5                               Ok
 4 a80c.0dea.e6b0 to a80c.0dea.e6bb 1.0                               Ok
 5 18e7.28a1.f700 to 18e7.28a1.f703 2.1 15.0(1r)SG10 03.05.00.E       Ok
 6 18e7.28a1.f704 to 18e7.28a1.f707 2.1 15.0(1r)SG10 03.05.00.E       Ok
 7 a80c.0dea.de40 to a80c.0dea.de4b 1.0                               Ok
GigabitEthernet4/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is a80c.0dea.e6b0 (bia a80c.0dea.e6b0)
  Description: --Etherchannel to SER1-1/1--
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLH
Here is your answer.
You should check
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matri
x/OL_6981.html#wp142660
This tells which release we start supporting an SFP and which release we start supporting
DOM.
This shows that GLC-LH-SMD does not support DOM as of now.
We have logged the bug for the same:
https://tools.cisco.com/bugsearch/bug/CSCum99103/?reffering_site=dumpcr
Inayath
*Plz rate all the usefull posts and mark the thread as answered if this solved your query.
9 Replies 9
InayathUlla Sharieff
This SFP is supported  on this switch.
 http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_27989-01.html#92299
could you please share the output of transciever details so that i see what it is showing?
Inayath
Can you run this cmd:
sh int transceiver detail
That is my issue unfortunately it displays nothing as you can see:
admin-sw1#sh int transceiver detail
admin-sw1#
admin-sw1#
I have 8 x GLC-LH-SMD= spread across blades 4 and 7 but no status details are displayed
You should check
DOM.
Inayath
Thx Inayath for the info
Issue:
4500 switch, show interface transceiver fails to display any details.
Bug:
CSCum99103 unfortunately doesn't seem to be publicly available.
Questions:
Has this bug been resolved in the meantime?
If so:
Which 4500 software versions were affected?
In which 4500 software versions has it been resolved?
If not:
Is there a workaround?
hI
That BUG is restricted from public view from Cisco,you would have to request to view it and they still may block it if there is something sensitive they may not want to release
Steve Wood
I just get returned to the command prompt when I issue any combination of "sh interface transceiver ?"
aceandy79
Having looked at our 4500X switches it appears to be the case that "show interfaces transceiver" only produces output on 10Gb optics. With 1Gb SFPs  you get no output even though as already mentioned by the OP this works on other Catalyst products and I have also seen it works on Nexus 7000.
