show platform hardware capacity - % of processor memory consumption for linecard
Carlos T
I have a 7609 ROUTER with dual sup 720-3BXL. In slot 1 there is a WS-X6704-10GE line card.
I have noticed in the output of the command "show platform hardware capacity" that the % of Processor memory consumption for the slot 1 line card (WS-X6704-10GE ) keeps in 66%. I have also realoaded the whole device, and after the reload and without receving traffic of any sort, the value still keeps in 66%.
Anyone can help me know the reasons or why it keeps over 66%?
as the value is above 60% could it impact the device or the traffic of the line card?
CPU Resources
  CPU utilization: Module             5 seconds       1 minute       5 minutes
                   1                   3% /  0%             3%              4%
                   2                   0% /  0%             0%              1%
                   5  RP               1% /  0%             3%              3%
                   5  SP               9% /  0%            10%             10%
                   6  RP               1% /  1%             2%              2%
                   6  SP               4% /  0%             4%              4%
                   7                   0% /  0%             0%              0%
                   8                   0% /  0%             0%              0%
                     9                   8% /  0%             4%              4%
    Processor memory: Module   Bytes:       Total           Used           %Used
                      1                 199202464      131292504             66%
                      2                 199202464       59625396             30%
                      5  RP             907965104      164174592             18%
                      5  SP             864238844      192452116             22%
                      6  RP             907915376      146862072             16%
                      6  SP             854143676      180366276             21%
                      7                 199202464       58418008             29%
                      8                 199202464       58391932             29%
                      9                1004508704      184002664             18%
    I/O memory: Module         Bytes:       Total           Used           %Used
                5  RP                    67108864       14337996             21%
                5  SP                    67108864       11743144             17%
                6  RP                    67108864       14337996             21%
                6  SP                    67108864       11743144             17%
I have another 7609 router with the exactly the same hardware and software configuration and heavy loaded with traffic, but the for thta same model linecard the value is in 40%
Carlos Trujillo.
Shashank Singh
Hi Carlos,
High CPU on WS-X6704-10GE CFC/DFC is a known issue. Please see the following:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsj38112
There is no impact to the forwarding of traffic/performance on the linecard.
Cheers,
Shashank
P.S. Please rate if this helped answer your question.
