Simple Cisco 891W setup at home
Starmo975
I am new to the community and will need some help. I have a Cisco 891W Wireless Router which I would like to use at home. Switch is new and has not been programmed before.
I would like to set up this router as additional router in home next to my Linksys  or Netgear  routers.
First I need to know if I would be able to get the IP from my routers or would I need to get it straight from the ISP modem for 891W to work properly.
Are there any instructions on how to set up this router in a simple mode without connecting it to the network management servers?
All I need to use is the Wi-Fi capability with WPA security applied to SSID.
Thank you in advance!!!
Starmo975
Anybody able to help me?
