simple command help needed
r.norton
Community Member
I have a switch on top of a water tower and need to verify what devices are connected to each port on the switch. Is there a command I can use to view IP info of each device connected to the switch? it is a WS-C2955T-12
bjw
Level 8
Level 8
You can use show CDP nei detail to find any Cisco CDP enable devices that are connected.
A show mac-address will give you a list of all connected mac-addresses, from that you can go to the default gateway device and discriminate each MAC address from show ip arp commands
From that you'll have MAC-Port#-IP Address
