simple command question
gisdmis1968
Community Member
what command do i use to remove this line from pix?
static (inside,outside) tcp x.x.x.x smtp mailfilter smtp netmask 255.255.255.255 0 0
pstebner1
Level 4
Level 4
no static (inside,outside) tcp x.x.x.x smtp mailfilter smtp netmask 255.255.255.255 0 0
hth,
paul
yeah that is what i thought and tried and it kept giving me an error
no static then all the info i had in there
leave of the last "0 0". If that doesn't work ( it should - I just tested it on mine) reboot the PIX and try again.
hth,
Paul
thanks i will try that in the morning, thanks for the help
