Simple EEM script
Drew Browning
Level 3
Level 3
I am trying to create a simple manual EEM script so when you login to a switch and run "event manager run tshoot" it will run the follow EEM script and show the interfaces in an error disabled script.  The switch takes the configuration, but when I run the script it never disables anything.  Any thought?
event manager applet tshoot
event none
action 1.0 cli command "enable"
action 2.0 cli command "show interface status | in err"
dmuinoorallo
Level 4
Level 4
You can try this:
 event cli pattern "show interface status" sync yes
 action 111 cli command "enable"
 action 112 cli command "show interface status | in error"
 action 113 puts "$_cli_result"
 action 114 set _exit_status "0"
I hope it will be working fine
