Simple HSRP Question
sullivan.p
Hi All,
Hoping to get some clarification around something I'm having trouble finding a definitive answer on in the Cisco Docs.
My Question - If an HSRP interface whose priority is decremented based on a IP SLA tracked object being offline is re-incremented before the preemption delay of the other HSRP router has completed, does that 're-incrementation' of the preferred HSRP interface reset or cancel the preemption?
Or is it once a preemption action has been initiated, does the re-incrementation of the preferred interface have no effect on the preemption and it continues to failover the active HSRP interface to the lower priority HSRP interface?
I have an HA Internet scenario, using two routers in an HSRP v2 setup, with upstream objects being tracked using IP SLA targets to decrement the configured priority of Router A (Priority 100 HSRP Preferred Router) by 60. the configured priority of Router B is 50 (HSRP - Backup RTR). Therefore when the upsteam IP SLA targets are identified as not responding, the preferred Router A's HSRP interface priority is decremented by 60, and a preemption takes place. My intended configuration is that this preemption is delayed by 30 secs to avoid false positives, but I just want to be sure that this is in fact what I can expect.
That if the IP SLA targets configured on Router A come back online before the preemption delay period has completed, that the priority of Router A's HSRP interface is re-incremented to 100 and the preemption is cancelled before Router B has had a chance to takeover.
Hope that makes sense. Any help much appreciated, and if you can point me in the direction of any KB articles that would be very useful.
Patrick
2 Accepted Solutions
smehrnia
Level 7
Level 7
Hi there,
I have never experienced this condition in a Lab before, but from my readings, due to the fact that "preempt delay" is a timer that is used to give some time to Standby router to populate its routing table before becomming active. I guess as soon as the coupe message is exchanged, the standby router sets to become active, and whatever rolls back will take effect after the timer expires, and a new coupe message exchanged.
preempt timer is not there to prevent flapping, I guess. btw I'd be happy if you let me know if its otherwise.
Link:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094a91.shtml#preemption
plz Rate if it helped,
Soroush.
Hope it Helps!
Soroush.
siddhartham
Level 4
Level 4
As Soroush explained, Prrempt delay specifies the time the new HSRP standby Router waits before take over the active role from the peer HSRP router.
In your case:
1) Initial condition
--- RouterA-priority100-Active router    RouterB-Pr50-Standby Router
2) IP SLA Target on RouterA stopped responding
--- RouterA-priority40    RouterB-Pr50 ---Router B immediately becomes the Active Router
3)Preempt Dealy min 180 and preempt command configured on RouterA
--- When the priority on RouterA is back to 100 (means the IP SLA target start responding) RouterA will start the count down timer and wait 3 min (180sec) then take over the active role from Router B.
Siddhartha
handoko wiyanto
Level 3
Level 3
hi Patrick,
would you post that HSRP and IP SLA config to the forum here?
regards,
smehrnia
Level 7
Level 7
Hi there,
Link:
Soroush.
Hope it Helps!
Soroush.
siddhartham
Level 4
Level 4
In your case:
Siddhartha
Thanks for the responses, tested this in the lab today and it indeed looks like each coup message requires its own preemption delay period.
Thanks again,
Patrick.
