Not able to create more than 256 VLAN in N5k
netops044
I am not able to create more than 256 VLAN in Cisco Nexus 5010 switch. While creating I am getting "No VLAN resources available for VLAN creation" Details below -
Switch model - 5010
Software : NX OS 4.0 (1a)
Error Message:
Nexus_5010(config)# vlan 417
ERROR: No VLAN resource available for VLAN creation
Nexus_5010(config)#
VLAN resource command output -
Nexus_5010# sh resource vlan
     Resource               Min       Max      Used    Unused     Avail
     vlan                    16       256       256         0         0
Nexus_5010#
Sh  version of the switch -
Nexus_5010# sh ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2008, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 1.2.0
  loader:    version N/A
  kickstart: version 4.0(1a)N1(1)
  system:    version 4.0(1a)N1(1)
  BIOS compile time:       06/19/08
  kickstart image file is: bootflash:/n5000-uk9-kickstart.4.0.1a.N1.1.bin
  kickstart compile time:  12/3/2008 5:00:00 [12/03/2008 18:38:37]
  system image file is:    bootflash:/n5000-uk9.4.0.1a.N1.1.bin
  system compile time:     12/3/2008 5:00:00 [12/03/2008 19:14:18]
Hardware
  cisco Nexus5010 Chassis ("20x10GE/Supervisor")
  Intel(R) Celeron(R) M CPU    with 2074308 kB of memory.
  Processor Board ID JAF1423EBLE
  Device name:Nexus_5010
bootflash:    1003520 kB
Kernel uptime is 613 day(s), 14 hour(s), 46 minute(s), 30 second(s)
Last reset
  Reason: Unknown
  System version: 4.0(1a)N1(1)
  Service:
plugin
  Core Plugin, Ethernet Plugin
Nexus_5010#
Yes, it seems the limit was increased in later releases. I have done a quick search and limit was bumped up to 512 vlans in 4.1(2)E1(1)  and later.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
5 Replies 5
Ivan Shirshin
This switch tested limit is of 256 vlans. This includes 5 reserved vlans and 251 user configured vlans.
NX-OS enforces this limit and you cannot create more than that. Looking at your resources, you have already used up all of them:
     vlan                    16       256       256         0         0
Kind Regards,
Ivan
Kind Regards,
Ivan
netops044
Cisco Nexus 5000 Series Configuration Limits for Cisco NX-OS Release 5.0(3)N1(1b) - http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration_limits/limits_503/nexus_5000_config_limits_503_n1_1b.html
The above document saysmaximm limit is 507..
Table 1     Cisco NX-OS Release 5.0(3) Layer 2 Topology Configuration Limits
Feature
Cisco Nexus 5000 Platform
Cisco Nexus 5500 Platform
Verified Topology1
Maximum Limits2
Verified Topology1
Maximum Limits2
Active VLANs/VSANs per switch
504
507
(504 when FCoE is enabled)
31 are set aside for VSANs and the remaining are for VLANs.
4013
(31 are set aside for VSANs and the remaining are for VLANs)
4013
Though it s for different software. My questions are -
1. Does max vlan dpends on software ?
2. Will I be getting 507 supported VLAN if i upgrade the software of my switch from 4.0 to 5.0 ?
Kind Regards,
Ivan
Kind Regards,
Ivan
Yes Ivan, I have used 4.1 and now VLAN limit increased to 507.
Thanks.
welcome!
Kind Regards,
Ivan
Kind Regards,
Ivan
