Simple Networking question SG 200-18 Switch
gkonheiser
Hi There
I have 5 hosts on sublnet 192.168.66.x all patched into a Cisco SG200-18. My Gateway is 192.168.66.1.
Now this is the thing. When I remove the gateway in the IP Setting of any of the clients I lose connectivity to that client from the other clients in the subnet???
Anyone have any ideas why this is?
9 Replies 9
cadet alain
hi,
if all clients are in same L2 broadcast domain then it should not happen because when communicating they are not using the default gateway.
Can you provide ipconfig/all of  2 clients having problems when default gw is removed
provide also arp cache and routing table: arp -a and route print if Windows clients.
Regards.
Alain.
Thats exacly it  they are in the same broadcast domain and I have never had this happen before, is very strange.
There is the ipconf/all, arp -a and route print from two of the client having the problem, thx for your help :-
C:\>ipconfig/all
Windows-IP-Konfiguration
   Hostname  . . . . . . . . . . . . : icdcc103
   Primäres DNS-Suffix . . . . . . . :
   Knotentyp . . . . . . . . . . . . : Hybrid
   IP-Routing aktiviert  . . . . . . : Nein
   WINS-Proxy aktiviert  . . . . . . : Nein
Ethernet-Adapter LAN-Verbindung:
   Verbindungsspezifisches DNS-Suffix:
   Beschreibung. . . . . . . . . . . : Intel(R) 82578DM Gigabit Network Connecti
on
   Physikalische Adresse . . . . . . : 2C-27-D7-21-F7-F7
   DHCP aktiviert. . . . . . . . . . : Nein
   Autokonfiguration aktiviert . . . : Ja
   Verbindungslokale IPv6-Adresse  . : fe80::f530:90e7:3932:ecd8%12(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 192.168.66.103(Bevorzugt)
   Subnetzmaske  . . . . . . . . . . : 255.255.255.0
   Standardgateway . . . . . . . . . : 192.168.66.1
   DHCPv6-IAID . . . . . . . . . . . : 254552023
   DHCPv6-Client-DUID. . . . . . . . : 00-01-00-01-15-64-E1-74-2C-27-D7-21-F7-F7
   DNS-Server  . . . . . . . . . . . : 192.168.66.1
                                       8.8.8.8
   NetBIOS über TCP/IP . . . . . . . : Aktiviert
Tunneladapter isatap.{80ACCD47-3036-4D17-8D72-C5EE07EBAB5B}:
   Medienstatus. . . . . . . . . . . : Medium getrennt
   Beschreibung. . . . . . . . . . . : Microsoft ISATAP Adapter
   Physikalische Adresse . . . . . . : 00-00-00-00-00-00-00-E0
Tunneladapter LAN-Verbindung* 11:
   Beschreibung. . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
   IPv6-Adresse. . . . . . . . . . . : 2001:0:5ef5:79fd:30f0:1f73:3f57:bd98(Bevo
rzugt)
   Verbindungslokale IPv6-Adresse  . : fe80::30f0:1f73:3f57:bd98%11(Bevorzugt)
   Standardgateway . . . . . . . . . : ::
   NetBIOS über TCP/IP . . . . . . . : Deaktiviert
C:\>arp -a
Schnittstelle: 192.168.66.103 --- 0xc
  Internetadresse       Physische Adresse     Typ
  192.168.66.1          84-a8-e4-a3-05-d1     dynamisch
  192.168.66.5          10-8c-cf-cf-93-be     dynamisch
  192.168.66.10         00-1a-62-03-04-26     dynamisch
  192.168.66.20         9c-8e-99-f8-b2-b8     dynamisch
  192.168.66.30         2c-27-d7-11-0d-3b     dynamisch
  192.168.66.31         2c-27-d7-11-19-9e     dynamisch
  192.168.66.100        2c-27-d7-21-f7-61     dynamisch
  192.168.66.102        2c-27-d7-21-f7-6b     dynamisch
  192.168.66.104        78-ac-c0-a5-5c-61     dynamisch
  192.168.66.105        78-ac-c0-a5-5c-6d     dynamisch
  192.168.66.255        ff-ff-ff-ff-ff-ff     statisch
  224.0.0.2             01-00-5e-00-00-02     statisch
  224.0.0.22            01-00-5e-00-00-16     statisch
  224.0.0.252           01-00-5e-00-00-fc     statisch
  239.255.255.250       01-00-5e-7f-ff-fa     statisch
  255.255.255.255       ff-ff-ff-ff-ff-ff     statisch
C:\>route print
Schnittstellenliste
12...2c 27 d7 21 f7 f7 ......Intel(R) 82578DM Gigabit Network Connection
  1...........................Software Loopback Interface 1
13...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
11...00 00 00 00 00 00 00 e0 Microsoft Teredo Tunneling Adapter
IPv4-Routentabelle
Aktive Routen:
     Netzwerkziel    Netzwerkmaske          Gateway    Schnittstelle Metrik
          0.0.0.0          0.0.0.0     192.168.66.1   192.168.66.103    266
        127.0.0.0        255.0.0.0   Auf Verbindung         127.0.0.1    306
        127.0.0.1  255.255.255.255   Auf Verbindung         127.0.0.1    306
  127.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    306
     192.168.66.0    255.255.255.0   Auf Verbindung    192.168.66.103    266
   192.168.66.103  255.255.255.255   Auf Verbindung    192.168.66.103    266
   192.168.66.255  255.255.255.255   Auf Verbindung    192.168.66.103    266
        224.0.0.0        240.0.0.0   Auf Verbindung         127.0.0.1    306
        224.0.0.0        240.0.0.0   Auf Verbindung    192.168.66.103    266
  255.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    306
  255.255.255.255  255.255.255.255   Auf Verbindung    192.168.66.103    266
Ständige Routen:
  Netzwerkadresse          Netzmaske  Gatewayadresse  Metrik
          0.0.0.0          0.0.0.0     192.168.66.1  Standard
IPv6-Routentabelle
Aktive Routen:
If Metrik Netzwerkziel             Gateway
11     58 ::/0                     Auf Verbindung
  1    306 ::1/128                  Auf Verbindung
11     58 2001::/32                Auf Verbindung
11    306 2001:0:5ef5:79fd:30f0:1f73:3f57:bd98/128
                                    Auf Verbindung
12    266 fe80::/64                Auf Verbindung
11    306 fe80::/64                Auf Verbindung
11    306 fe80::30f0:1f73:3f57:bd98/128
                                    Auf Verbindung
12    266 fe80::f530:90e7:3932:ecd8/128
                                    Auf Verbindung
  1    306 ff00::/8                 Auf Verbindung
11    306 ff00::/8                 Auf Verbindung
12    266 ff00::/8                 Auf Verbindung
Ständige Routen:
  Keine
C:\Users\icdbb>ipconfig/all
   Hostname  . . . . . . . . . . . . : icdbb102
on
   Physikalische Adresse . . . . . . : 2C-27-D7-21-F7-6B
   Verbindungslokale IPv6-Adresse  . : fe80::8913:d461:7773:9783%12(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 192.168.66.102(Bevorzugt)
   DHCPv6-Client-DUID. . . . . . . . : 00-01-00-01-15-64-E1-C3-2C-27-D7-21-F7-6B
   DNS-Server  . . . . . . . . . . . : 8.8.8.8
                                       8.4.4.4
Tunneladapter isatap.{3D74A823-E880-4BFE-8207-9F9A0C779C4E}:
   IPv6-Adresse. . . . . . . . . . . : 2001:0:4137:9e76:475:3c54:3f57:bd99(Bevor
zugt)
   Verbindungslokale IPv6-Adresse  . : fe80::475:3c54:3f57:bd99%11(Bevorzugt)
C:\Users\icdbb>arp -a
Schnittstelle: 192.168.66.102 --- 0xc
  192.168.66.103        2c-27-d7-21-f7-f7     dynamisch
C:\Users\icdbb>route print
Schnittstellenliste
12...2c 27 d7 21 f7 6b ......Intel(R) 82578DM Gigabit Network Connection
IPv4-Routentabelle
Aktive Routen:
          0.0.0.0          0.0.0.0     192.168.66.1   192.168.66.102    266
     192.168.66.0    255.255.255.0   Auf Verbindung    192.168.66.102    266
   192.168.66.102  255.255.255.255   Auf Verbindung    192.168.66.102    266
   192.168.66.255  255.255.255.255   Auf Verbindung    192.168.66.102    266
        224.0.0.0        240.0.0.0   Auf Verbindung    192.168.66.102    266
  255.255.255.255  255.255.255.255   Auf Verbindung    192.168.66.102    266
Ständige Routen:
IPv6-Routentabelle
Aktive Routen:
11    306 2001:0:4137:9e76:475:3c54:3f57:bd99/128
                                    Auf Verbindung
11    306 fe80::475:3c54:3f57:bd99/128
                                    Auf Verbindung
12    266 fe80::8913:d461:7773:9783/128
                                    Auf Verbindung
Ständige Routen:
  Keine
all looks good except you have host routes for each client that shouldn't be the case.
Now remove the default gateway, clear the arp cache with arp-d * and do the ping and post the route print -4 and arp -a again
Regards.
Alain.
Hi Alain
Problem is I am at a remote location. Not sure how the routes you mentioned got in there as they are freshly installed boxes. I will try and remove the routes nag get back to you.
Thx again for taking the time
Gordon
Hi Alain
Here are the results of route print -4 and arp -a  after removing the gateway and doing arp -d :-
C:\Windows\system32>route print -4
Schnittstellenliste
IPv4-Routentabelle
Aktive Routen:
Ständige Routen:
Schnittstellenliste
IPv4-Routentabelle
Aktive Routen:
Ständige Routen:
  Keine
C:\Windows\system32>arp -a
ok so you still got that host route for your own address and no more default route and you only did it for one host.
So I suppose you deleted default gateway but arp got the other address you were pinging.
Was the ping successful ?
Can you try this : delete default gateway, clear arp cache, delete that host route with route delete command , all these on both hosts and then do a ping from 102 to 103 and post output of route table, arp cache on both hosts and ping result on 102.
Regards.
Alain.
Sorry to have to ask  but which host route is it that I should delete?
But I just verified and indeed this is normal I didn't remember this fact sorry for the misinformation.
Anyway you can do all the rest and provide result.
Regards.
Alain.
Hi Alain
I found the problem. With Windows 7 when you remove the gateway it changes the Network type to Public and enforces a sperate set of firewall rules for public networks  which basicly blocks nearly evrything. All sorted now, thanks for your help.
Gordon
