Simple Routing Issue
newtocisco2012
Afternoon Everyone,
Appologies for such a basic question but i'm just getting started with cisco kit so you will have to bare with me.
I have a cisco 1841,
Fa0/0 has the ip of 192.168.5.20
Fa0/1 has the ip of 10.0.0.1
Fa0/0 goes off to the Default gateway of 192.168.5.254
Fa0/1 goes off to a switch where I have a test machine connected (Ip 10.0.0.5).
From the router I can ping 8.8.8.8 for example and it's fine.
From the test computer I am unable to.
I added the "ip route 0.0.0.0 0.0.0.0 192.168.5.254" which then allow the router to ping 8.8.8.8
I realise I am probably making a very basic mistake but would appriciate some points or hints as to where I am going wrong.
Below is the config:
Password:
R1#show run
Building configuration...
Current configuration : 847 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$wssO$VhBou3PyVzg.IbEz4.4xv/
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip domain lookup
interface FastEthernet0/0
ip address 192.168.5.20 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.0.0.1 255.255.255.0
duplex auto
speed auto
ip classless
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password test
logging synchronous
login
line vty 5 15
password test
logging synchronous
login
end
If anyone could help that would be greatly appriciated.
Am I right in thinking I would have to create some sort of NAT rule from the inside to outside. or am I going down the wrong path here
cadet alain
yes you're right, just do NAT and it shall work:
access-list 1 permit 10.0.0.0 0.0.0.255
ip nat inside source list 1 interface f0/0
int f0/0
ip nat outside
int f0/1
ip nat inside
Regards.
Alain.
cadet alain
int f0/0
ip nat outside
int f0/1
ip nat inside
Regards.
Alain.
Thank you for your fast reply alain.
Just to get this correct so I understand, all we have done here is effectively called fa0/0 outside and 0/1 inside.
A new access list has been created for the network 10.0.0.0
We have then told the router that if any traffic from the inside interface in list 1 matches 10.0.0.0 to send it to the outside interface 0/0
any source address matching access-list 1 entering the inside interface will get translated to the IP address of the outside interface along with a port number so this is called NAT overload( many to one). So from the outside the source IP is the outside IP.
Regards.
Alain
