3750X QoS issue
jerome.gomez
i recently configured QoS on 3750x (12.2(55)SE1 ip base)to mark packets regarding access lists (here is a config extract)
mls qos
class-map match-any test
match access-group name ACL-Test
policy-map Ports-access
class test
  set dscp ef
class class-default
  set dscp default
interface GigabitEthernet1/0/1
desc access port
switchport access vlan 30
switchport mode access
duplex full
service-policy input Ports-access
interface GigabitEthernet4/1/4
description Inter switch link
no switchport
ip address XXXXXXXXX
ip pim dense-mode
ip ospf hello-interval 1
ip ospf dead-interval 3
mls qos trust dscp
ip access-list extended ACL-test
permit ip host 172.16.30.21 any
permit ip host 172.16.30.22 any
permit ip host 172.16.30.30 any
The object of this policy is just to mark packets. It's working well (sniffer shows packets marked as expected)
However for an unknown reason, the traffic marked is "policed" to 35% of global bandwidth.
When i apply service policy on interface, and i use a jperf i see only 35Mb/s on jperf server
When i remove service policy, i'm able to see 90Mb/s
Jperf client and server are on the same stack
Thanks for your help
regards
7 Replies 7
rizwanr74
Level 7
Level 7
You have auto-qos enable in the same segment ?
no auto qos is not applied on same segment. The config is exactly the one depicted in my post
regards
Vivek Ganapathi
Level 4
Level 4
Hi Jerome,
Could you please post the below outputs?
show inter Gi1/0/1 | in drops|queue|output
show mls qos inter Gi1/0/1 queueing
show platform port-asic stats drop Gi1/0/1
NOTE : Do clear the counters before taking these outputs. keep the service-policy applied. Generate the traffic using Jperf & record the outputs.
Also, as rizwan stated, was auto-qos enabled ? Basically what happens is, Auto-QoS configures the priority Q to be 25% of the bandwidth. If there is an exceed in the traffic, then default behaviour is to police the traffic. Probably, you can add the statement priority-Queue out on your uplink & see if the issue resolves. But do post the outputs for those above commands.
Vivek
Hi Vivek,
I'm waiting for infos from on site engineer.
XXX#show interfaces gigabitEthernet 3/0/3 | in drps |                ops | queue | output
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:00, output hang never
  5 minute output rate 12000 bits/sec, 13 packets/sec
     8930986 packets output, 1939664289 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
XXX#show mls qos interface gigabitEthernet 3/0/3 queueing
GigabitEthernet3/0/3
Egress Priority Queue : enabled
Shaped queue weights (absolute) :  0 0 0 0
Shared queue weights  :  1 97 1 1
The port bandwidth limit : 100  (Operational Bandwidth:100.0)
The port is mapped to qset : 1
XXX#show platform port-asic stats drop gigabitEthernet 3/0/3
  Interface Gi3/0/3 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 4
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 5
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 6
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 7
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
12P-SWH-C001#
Hello Jerome,
Is this the interface which is carrying outbound traffic? Looks like not. I need the outputs from the interface which is carrying traffic outbound. The config shows the port to be Gi1/0/1, but your outputs are from 3/0/3 ?
Let me know which interface you have your Jperf client / server sitting on?
Vivek
try updating the ios to 15.0
