Simple Stacking Question - 3650
toprock1970
Visitor
Hi guys
Is it possible to stack a 24 port 3650 with a 48 port 3650 if they both have the same IOS version.
I've not seen any documentation to say I can't, but I've also not seen anything to say I can.
Any help would be greatly appreciated.
Jason
Reza Sharifi
Yes, you can have a mix of 24 port and 48 port switches in a stack, as long as they both have the same exact IOS installed.
Reza Sharifi
Thank you for your reply Reza.
I shall now order the pair.
Jason
