Simulated link failure w/OSPF in Packet Tracer
brian03801
Hey gang,
I've been using Packet Tracer (v7) to do a little bit of design work and what not, and I noticed a peculiar problem when I simulate a link failure in a very basic OSPF environment. At first I thought maybe it was my config (knocking some dust off, and I was playing with multi-area OSPF), but I stripped it down the vanilla-est of vanilla with a single area OSPF config, and I'm still having the same problem.
So, the problem: Whenever I simulate a link failure on any of my routers, I lose ALL of their previously learned OSPF routes, and they never recalculate routes no matter how long I wait. Is this a bug in PT v7? All of the OSPF timers are set to default. All routers still show adjacency with their directly connected neighbors. I feel like I'm either going crazy, or I'm missing something so obvious that I'm going to be embarrassed. Thanks for any help!
I pasted the configs below. Like I said, vanilla.
When I simulate the link failure between R1 and R3, debug shows the following output:
Interface down or detached
00:23:34: OSPF: Build router LSA for area 0, router ID 10.3.3.3, seq 0xffffffff80000008
00:23:34: OSPF: DR/BDR election on GigabitEthernet0/0
00:23:34: OSPF: Elect BDR 0.0.0.0
00:23:34: OSPF: Elect DR 0.0.0.0
00:23:34: DR: none BDR: none
00:23:34: OSPF: Build router LSA for area 0, router ID 10.3.3.3, seq 0xffffffff80000009
00:23:42: OSPF: Rcv hello from 10.2.2.2 area 0 from GigabitEthernet0/2 10.3.10.6
00:23:42: OSPF: End of hello processing
R3#show ip ospf ne
Neighbor ID Pri State Dead Time Address Interface
10.2.2.2 1 FULL/BDR 00:00:33 10.3.10.6 GigabitEthernet0/2
R3#
00:31:02: OSPF: Rcv hello from 10.2.2.2 area 0 from GigabitEthernet0/2 10.3.10.6
_____________________________________________
Configs:
R1:
Current configuration : 877 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX15246X2G
spanning-tree mode pvst
interface Loopback1
ip address 10.1.1.1 255.255.255.255
interface GigabitEthernet0/0
ip address 10.3.10.10 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.3.10.1 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 10.3.10.0 0.0.0.3 area 0
network 10.3.10.8 0.0.0.3 area 0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
______________________________________________
R2:
version 15.1
hostname R2
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524CG3O
interface Loopback1
ip address 10.2.2.2 255.255.255.255
no ip address
duplex auto
speed auto
shutdown
ip address 10.3.10.2 255.255.255.252
duplex auto
speed auto
ip address 10.3.10.6 255.255.255.252
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router ospf 1
network 10.3.10.4 0.0.0.3 area 0
ip classless
line con 0
line aux 0
line vty 0 4
login
end
R3:
Current configuration : 876 bytes
version 15.1
hostname R3
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX152417FF
interface Loopback1
ip address 10.3.3.3 255.255.255.255
ip address 10.3.10.9 255.255.255.252
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 10.3.10.5 255.255.255.252
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router ospf 1
ip classless
line con 0
line aux 0
line vty 0 4
login
end
rf-mosmad
I have this problem too. I hope it's a Packet Tracer bug.
Hello, exactly the same problem, all the ospf routes disappeared on the routers with the link cut. I have to force the re-convergence SPF algorithme by reboot a router or re-enter the router ospf commands.
Have you some news? (pkt v7.0 64bits)
wmue
Had this problem too with PT 7.1
Problem seems to be solved in 7.1.1
https://www.netacad.com/group/offerings/packet-tracer/
( Packet Tracer 7.1.1 for Windows 64 bit.exe )
