Simulating small branch office in lab network
phonetech
I have to setup what seems to be a very basic configuration, but it doesn't work.
In our lab there is a cluster of switches with a 3550 that does all the routing for vlans.
I need to simulate a sort of a small branch office that has one connection
to the outside world (the lab network).
Here is my design:
Vlan 230 (the internet)
A port on 3550 is in vlan 230 and is connected to e0/0 (172.26.230.150) on 2611 router.
e0/1 interface on a 2611 is (192.168.1.1).
A PC is connected to e0/1 (192.168.1.12).
From the router I can ping any host on vlan 230 and other vlans,
I can also ping the pc connected to e0/1.
However from the PC I can only ping 192.168.1.1(e0/1) and 172.26.230.150 (e0/0)
Below is my configuration
Thanks for your help.
R2611-1#sh run
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname R2611-1
ip subnet-zero
ip dhcp excluded-address 192.168.1.1 192.168.1.9
ip dhcp pool 192.168.1
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
interface Ethernet0/0
ip address 172.26.230.150 255.255.255.0
no ip directed-broadcast
no ip mroute-cache
no mop enabled
interface Ethernet0/1
no ip mroute-cache
ip classless
ip route 0.0.0.0 0.0.0.0 172.26.230.1
ip http server
no scheduler allocate
end
lgijssel
Level 9
Level 9
You are not performing nat on the router.
This is typically required on a box which provides internet connectivity.
Probably the other hosts on vlan 230 have no route back to the pc on 192.168.1.1
Configuring nat on the router will resolve this problem.
regards,
Leo
lgijssel
Level 9
Level 9
regards,
Leo
Thanks, I'll try that and will post results.
Leo, thank you very much for your help. It works now.
