NEXUS 5548 - can't get HSRP nor VRRp to work...
joyride_us2
I have my daughter L3 cards installed, features activated and the config is correct...both NEXUS ping each other and are directly connected through a vpc. Still, I land in a split-brain situation : debug shows that they do not receive each other's Hello packets.
Any clue ?
Thanks!
9 Replies 9
glen.grant
  Is the trunk across the vpc peer link setup  and working correctly ?  you would need to allow any vlans defined across the vpc peer link trunk .
Absolutely.
Reza Sharifi
Have you configured VPC keepalive using mgmt0?
Yes indee
Check spanning tree then and see if it sees one side as the root  across the peer link , this will tell you if the trunk is ok . Might have to post the config , not a lot to go on .  Nexus is a different beast...
Hmmmmm...none of the Nexus on each side of the peer-link is root for any VLAN.
vrf context management
  ip route 0.0.0.0/0 10.2.37.1
vpc domain 1
  peer-keepalive destination 10.2.37.50
interface Vlan1
interface Vlan99
  no shutdown
  ip address 10.47.100.250/24
  hsrp 1
    ip 10.47.100.252
interface port-channel1
  switchport mode trunk
  spanning-tree port type network
  speed 10000
  vpc peer-link
interface port-channel2
  speed 10000
  vpc 2
interface port-channel10
  speed 1000
  vpc 10
interface port-channel11
  speed 10000
  vpc 11
interface port-channel12
  speed 10000
  vpc 12
interface port-channel13
  speed 10000
  vpc 13
interface port-channel14
  speed 10000
  vpc 14
interface mgmt0
  ip address 10.2.37.51/24
line console
  Are the layer 2 vlans defined ?  Show vlan on each side to check..  Don't see them in just what you have posted.
Yes they are!
NEXUS3# sh vlan id 99
VLAN Name                             Status    Ports
99   management                       active    Po1, Po2, Po10, Po11, Po12
                                                Po13, Po14, Eth1/6, Eth1/8
