Single direction ACL
TechBhole241
Good afternoon,
  • My query related to ACL . If any user want to ACL for single direction apply then how can I apply on interface vlan it will be outbound or inbound. Please help me anybody. Related screenshot I have shared in this post .  1000037643.png
Mohan Singh
balaji.bandi
its all depends on the devices where you apply - Router/ Switch or Firewall
Firewalls are statefull
Router and Switches are stateless.
Single as per your requirement  only source can initiate the traffic to outside, (outside can not initiate the traffic back which will be denied.)
example if you like return traffic on router you can use established command to allow already intiated connection inside to outside:
https://community.cisco.com/t5/networking-knowledge-base/how-to-configure-acls-to-permit-only-established-connections-and/ta-p/3127503
more command syntax :
https://www.cisco.com/c/en/us/support/docs/security/ios-firewall/23602-confaccesslists.html
BB
Blue_Bird
Hello mohansingh2015knp,
Already mentioned......it's besed on where you want to create...Router/Switch(L3) or Firewall.
Based on image you provided...I understand that the requirement to create an Extended ACL. The Extended ACL's should be configured closure to the source. so,  You will be needed to impliment on the Source Interface in inbound direction.
Here is the sample configuration:
access-list 101 permit tcp host 10.206.213.131 10.0.0.0 0.255.255.255
access-list 101 permit tcp host 10.206.213.132 10.0.0.0 0.255.255.255
Interface Gigx/x
ip access-group 101 in
 Best regards
******* If This Helps, Please Rate *******
