01-19-2017 07:25 PM - edited 03-08-2019 08:59 AM
hello all,
I have config a Cisco 1941 with 1 WAN port assign 3 Public subnet IP, so where is wrong? please correct it.
\thanks very much!
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname cipp
enable password 123
ip dhcp excluded-address 192.168.23.81 192.168.23.220
ip dhcp pool cipp
network 192.168.23.0 255.255.255.0
default-router 192.168.23.254
dns-server 192.168.23.53 192.168.23.54
lease 0 2
ip domain name cipp.net
ip name-server 192.168.23.54
ip name-server 69.71.48.70
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524D402
username cipp privilege 15 secret 4 123
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address 192.168.23.254 255.255.255.0
ip nat inside
duplex auto
speed auto
ip virtual-reassembly in
interface GigabitEthernet0/1
ip address 75.44.192.36 255.255.255.248
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router rip
version 2
no auto-summary
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat pool 75 75.44.192.36 75.44.192.38 netmask 255.255.255.248
ip nat pool 76 76.44.192.48 76.44.192.62 netmask 255.255.255.240
ip nat pool 77 77.44.192.16 77.44.192.31 netmask 255.255.255.240
ip nat inside source list 1 pool 75
ip nat inside source list 1 pool 76
ip nat inside source list 1 pool 77
ip route 0.0.0.0 0.0.0.0 75.44.192.33
ip route 172.16.19.0 255.255.255.0 192.168.23.196
ip route 172.16.23.0 255.255.255.0 192.168.23.254
ip route 192.168.23.0 255.255.255.0 172.16.23.254
ip route 192.168.33.0 255.255.255.0 192.168.23.54
ip classless
ip flow-export version 9
access-list 1 permit 0.0.0.0 255.255.255.0
access-list 1 remark INSIDE_IF=GigabitEthernet0/0
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.23.0 0.0.0.255
access-list 23 permit 192.168.23.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
password 123
login
transport input all
end
01-19-2017 11:12 PM
Has the ISP told you to configure the two additional networks as you did? At least this is a quite uncommon way to implement it.
If not, just remove the subinterfaces. Typically, the ISP-side is configured in a way that the additional networks can be used in your NAT without any additional interfaces.
And don't configure your default route with the interface. Use the ip that the ISP told you as the gateway.
01-19-2017 11:19 PM
Thank you Karsten,
before M0N0wall configure these 3 public subnet. because 3 public subnet just 1 cable to my Router.
and now change router M0N0wall to Cisco 1941, so I configured 2 subinterfaces.
So I must remove subinterfaces?
