site to site vpn tunnel problems
carl_townshend
Hi all, my access points cannot see the wlse device due to the firewall, I am running a site to site vpn tunnel between 2 sites, im getting the below error, can anyone help on this ?
Connection attempt was prevented by "no forward" command: udp src outside:10.112.228.17/32777 dst inside:10.116.1.40/2887
hi,
the tunnel is between the firewall and router or router to router. if it between router and firewall make sure that there is no natting on the edge router (if yes allow isakmp udp ports on edge router).
Also make sure to allow required access using ACL from both sides (Outside and Inside)
Hi there, the tunnel is between 2 asa firewalls, all traffic is fine going through the tunnel, but I cant ping through it ??
any ideas
carl_townshend
can anyone help on this asap ?
