Sizing vPC peer-link
rlawoaud6
I'm considering vPC configuration with N9K x 2 units.
According to the recommended configuration(below link), vPC peer link is 10G interface x 2 and
vPC Peer-Keepalive link is 1G x 1.
Anyway, I want to check if there is no problem with the following configuration.
vPC peer link:100G x 1
vPC Peer-Keepalive link:1G x1
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
Thanks!
balaji.bandi
vPC peer link:100G x 2  <<-- always suggest to have 2 links
But 100GB is too high (again depends on where you deploying servers and environment.
We do have many deployments of 9K we use 20Gbx2 it was not saturated any point of time, By saying that we never seen any link failures between these vPC pairs.
Other than that operational poing of view 100GB SFP are expensive bit compare to 20GB /40GB, on top you need to keep some spare of required to replace or test.
BB
Seb Rupik
Hi there,
Redundancy is vitally important for a vPC peer-link, which is why two member links are recommended. 100G has significantly more bandwidth, but is highly susceptible to vPC failure if that single link goes down!
cheers,
Seb.
balaji.bandi
BB
