How apply settings that 'standby console enable' permanetly?
GaeMi
Hello.
I using switch cisco 6500.
when I connected console in standby switch, I saw 'standby console disabled'.
Therefore, I inserted settings standby console enable, and save.
but when switch is reloaded, the settings disappear.
2 Accepted Solutions
how did you configure this, like below ?
6500(config)#redundancy
6500(config-red)#main-cpu
6500(config-r-mc)#standby console enable
Giuseppe Larosa
Hello GaeMi,
in a catalyst with two supervisors even using SSO the standby supervisor console cannot be accessed by default.
Try the procedure described in the following thread to see if you can enable it.
see
https://community.cisco.com/t5/switching/console-session-disabled-on-standby-supe-4507/td-p/1990850
Switch#conf t
Switch(config)#redundancy
Switch(config-red)#main-cpu
Switch(config-r-mo)#standby console enable
However, to be noted in a different platform like ASR9000 with two Route Processors running IOS XR both console are available and can be used at the same time by default. I did it.
Hope to help
Giuseppe
Thank you for your reply.
Giuseppe Larosa
Hello GaeMi,
see
Switch#conf t
Hope to help
Giuseppe
Thank you!
I already inserted this commands in the switch.
but, when switch was rebooted, not applied.
I have tried and rebooted several times, It was applied from a certain moment.
I don't know detail reasons... Anyway, things went well.
