Slip Sec Error How to solve?
rodrigofck
I?m having a slip sec error. Somebody knows how can i solve this problem? Thanks A lot!
#sh run
controller E1 0/1
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
country brazil
metering
answer-signal group-b 1
____________________________________________________________________________________
#sh controllers e1
E1 0/1 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20051006, FPGA: 20, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (29 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
3 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
3 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 82 15 minute intervals):
1 Line Code Violations, 1088 Path Code Violations,
8646 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
8647 Errored Secs, 0 Bursty Err Secs, 1 Severely Err Secs, 101 Unavail Secs
#sh ver
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 28-Feb-06 23:31 by alnguyen
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
TelefoniaIP_Eng_Comercial_SC uptime is 1 day, 17 hours, 30 minutes
System returned to ROM by error - a SegV exception, PC 0x81CC5978 at 16:44:08 GM
T Mon Jul 30 2007
System restarted at 16:48:34 GMT Mon Jul 30 2007
System image file is "flash:c2600-ipvoice-mz.124-7.bin"
Cisco 2610XM (MPC860P) processor (revision 4.1) with 118784K/12288K bytes of mem
ory.
Processor board ID FTX0945A2UL
M860 processor: part number 5, mask 2
1 FastEthernet interface
1 Serial interface
1 Channelized E1/PRI port
1 ATM/Voice AIM
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Not applicable
I think Slips are usually caused by a clocking issue on the line. The clock source on your line is set for
line. Have you verified with the provider that they are providing clocking on the line? I am also
seeing AAL5 CRC errors on the subinterface of the ATM interface. These may be contributing to the SLIPS or vice-versa. The CRC errors could be caused by any one of the following:
Dropped cells due to traffic policing in the ATM cloud on one or more VCs attached to the ATM
interface.Noise, gain hits, or other transmission problems on the data-link equipment.
For more information please click following URL:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_system_message_guide_chapter09186a0080080f7c.html#wp1025806
