SLM248G latest firmware
br3schweiz
Hi there
Has anybody by chance still the latest firmware for the small business switch SLM248G? Since it's EOS it's not anymore available in the official database...
Thank you very much for checking.
Viktor1010
I've found something in my archive, hope it helps. (Still runing on my SLM248G)
Viktor
10 Replies 10
danilorcesar
Did you get the firmware?
I need SLM224g firmware 2.0.0.10 or 1.0.x.
I don't know if the SLM248G firmware fits the SLM224G.
But I would like to try the upgrade!
Can you make the firmware available?
Hi there
No, unfortunately not... I'm sticking with version 1.0.0.8 - so far it runs stable...
Many thanks for the reply!
Can you please make this version 1.0.0.8 available?
attached the firmware...don't ask me where I found it. It is a .ros file (I zipped it in order to be able to upload it)...
This file does not work on the SLM2XX.
And if you check, it was me who made this firmware available in one of my posts.
It works on switches: SLM2024 and SLM2048.
ouch, my bad...I googled and found a link, no idea that was you...:(
I think it is rather not so good that Cisco removes the software for these EoL devices, after all, where else are you supposed to get them...
Viktor1010
Viktor
Thank you very much!
Hi I have cisco slm248g with flashing system led, I have I serial cable arriving tomorrow  so I can attempt to re install the ios. My question is, is ther a persific port I should connect to on the switch with the consol cable or any port from 1 to 48 will work thanks in advance for any help.
br3schweiz
That works, thank you very much!
