Slow command output cisco C9300-48U
We have two new cisco C9300-48U. when I ran it up and put one into production, it seemed fine.. but now when I issue the command 'sh auth sess' it takes over a minute to produce output :
camia#sh clock
13:14:15.613 AEDT Fri Feb 9 2018
camia#sh auth sess
Interface MAC Address Method Domain Status Fg Session ID
Gi1/0/2 00e0.db45.9a69 mab DATA Auth 1D1418AC0000012B2C326D3F
Gi1/0/3 00e0.db45.9a79 mab DATA Auth 1D1418AC0000309C783476B8
Gi1/0/1 00e0.db0f.ee68 mab DATA Auth 1D1418AC00002C0F4E9886A4
Gi1/0/4 00e0.db0e.e6e3 mab DATA Auth 1D1418AC000030B178451404
Session count = 4
Key to Session Events Blocked Status Flags:
A - Applying Policy (multi-line status for details)
D - Awaiting Deletion
F - Final Removal in progress
I - Awaiting IIF ID allocation
P - Pushed Session
R - Removing User Profile (multi-line status for details)
U - Applying User Profile (multi-line status for details)
X - Unknown Blocker
camia#sh clock
13:15:35.953 AEDT Fri Feb 9 2018
I'm also seeing this throughout the log
Feb 9 10:29:44.695 AEDT: %FMFP-3-OBJ_DWNLD_TO_DP_FAILED: Switch 1 R0/0: fman_fp_image: WRClient 0x165c44f3 download to DP failed
Feb 9 10:42:25.707 AEDT: %FMFP-3-OBJ_DWNLD_TO_DP_FAILED: Switch 1 R0/0: fman_fp_image: WRClient 0x113aa674 download to DP failed
We decided to upgrade to latest version Everest-16.6.2  ED and but still logs are coming but still slow in running the command.
upgraded to 16.2.2
camia#sh ver
Cisco IOS XE Software, Version 16.06.02
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.6.1r [FC1], RELEASE SOFTWARE (P)
and I'm still seeing the issue :
camia#sh clock
09:59:32.542 AEDT Mon Feb 19 2018
camia#sh auth sess
Gi1/0/2                  00e0.db45.9a69 mab     DATA    Auth        1D1418AC00000030A300AEDC
Gi1/0/4                  00e0.db0e.e6e3 mab     DATA    Auth        000000000000000BA300A053
Gi1/0/1                  00e0.db0f.ee68 mab     DATA    Auth        1D1418AC00000032A300B4B7
Gi1/0/3                  00e0.db45.9a79 mab     DATA    Auth        1D1418AC00000035A300BC37
Session count = 4
  P - Pushed Session
  X - Unknown Blocker
camia#sh clock
10:00:38.237 AEDT Mon Feb 19 2018
doing this command also takes a long time
camia#sh auth brief switch active r0
but doing either of these commands :
camia#sh auth sess int g1/0/1
camia#sh auth sess int g1/0/1 detail
is instant.. it just seems to be the enumeration process that seems to take a long time.
Does any one have faced same issue and found resolution ?
0 Replies 0
