Slow connection, could someone help me understand this int output...
Mark Mattix
Level 2
Level 2
I have a router that serves the connection to the Internet for 3 different areas. Users are getting a really slow connection and I'm trying to make sense of this interface that connects to the internet. The Internet line is supposed to be capable of 30Mbits a second.
According to this output is this interface receiving 5869000 bits (5.6Mbits) of data a second and only outputting at a rate of 1221000 bits (1.2Mbit) a second? If the connection is indeed 30Mbit a second should it be outputting closer to 31457280 bit (30Mbits) a second?
GigabitEthernet0/1 is up, line protocol is up
  Hardware is __ Ethernet, address is ****.****.****
  Internet address is 192.168.1.1/24
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 254/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is T
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 51/75/11032859/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 5869000 bits/sec, 1009 packets/sec
  5 minute output rate 1221000 bits/sec, 502 packets/sec
     596933819 packets input, 2456331000 bytes, 2628 no buffer
     Received 7266 broadcasts, 0 runts, 0 giants, 1021276 throttles
     15354216 input errors, 0 CRC, 0 frame, 37417 overrun, 15316799 ignored
     0 watchdog, 0 multicast, 0 pause input
     1820839956 packets output, 1477679970 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
6 Replies 6
vmiller
Level 7
Level 7
First thing, log onto this router and do a clear counters. then check 12 ore 24 hours later to see if the input errors overrun and ignored have increased. we cant tell from this how old the data is.
you might consider posting this routers config (with all confidential info removed)
singhaam007
Level 3
Level 3
hello Mark,
I will be more worried about reliability 254/255, txload 1/255, rxload 1/255
It suppose to be always reliability 255/255 so please check cables and replace them and try again same command.
We was having same issue with our core and changing cable fix the issue.
please rate if this helps
thanks
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Your input errors to received packets ratio is high enough it can be detrimental. This might be a contributing factor to your poor perceived performance.
Your snapshot stats also show a deep (51) input queue (generally unusual) and many input queue drops.  You might be able to reduce your input queue drops by expanding the input queue's depth, but this should be further investigated.
I see the connection is physically gig although note link supports 30 Mbps transfer rate.  What's the device?
If this is a low end router, you might also improve the situation by running g0/1 interface at 100 Mbps.
PS:
Some input queue and Ethernet interface Cisco documentation:
http://www.cisco.com/en/US/products/hw/modules/ps2643/products_tech_note09186a0080094a8c.shtml
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml#topic2
http://www.cisco.com/en/US/docs/internetworking/troubleshooting/guide/tr1904.html#wp1020879
http://www.cisco.com/en/US/products/hw/routers/ps167/products_tech_note09186a008012fb87.shtml
Mark Mattix
Level 2
Level 2
Thank you for the responses.
Amrinder, I will definately look into the wiring being the potential cause but the same issue also occurs else where at random times so I'm not sure if that will be the issue.
Joseph, Thanks for those links, they helped me undertsand this output a lot more. I'm not sure how to determine what's at the other end of the 30Mbit connection. You mentioned about changing the interface speed to 100Mbps, would this be done by using the "bandwidth 100000" command? I read in the link you sent me that lowering the speed could help prevent packets being put in queue. Would the txrate and rxrate be more accurate by lowering the speed as well?
Thanks for the help!
  what do you plug your ethernet cable into?
What model is the device you are using for this link? aswitch or a router ?
Disclaimer
Posting
No, by lowering the speed, I meant running the physical link at 100 Mbps rather than 1 Gbps.  This allows the router 10x the time to process back-to-back packets.  Since you're logical cap is 30 Mbps, it shouldn't be too adverse to total throughput.
The tx and rx rates tend to be accurate, but by default, they're a 5 minute average.  Setting the load-interval to the minimum, 30 seconds, will have them more closely track real-time performance, but on networks, with FastEthernet or faster interfaces, a lot can happen in 30 seconds.
