slow network
dsolangon
I have a very slow network i have input errors and crc error please see attached filed and see if you have initial findings
L2 Switched: ucast: 30699748 pkt, 2424085658 bytes - mcast: 5488306 pkt, 484304471 bytes
L3 in Switched: ucast: 2467261715 pkt, 174547700256 bytes - mcast: 2 pkt, 165 bytes mcast
L3 out Switched: ucast: 261213161 pkt, 161985629560 bytes
acampbell
Daryl,
Your inteface is claiming 100M Full Duplex and
you are seeing input/crc errors
There is a fair chance that the other end of the link/cable
is not set for 100M/Full duplex and is probably running half duplex
Can you find out what is sett at the other end of the link/cable
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Ok i will check ... But have seen any findings on my attached screenshot huge unicast n multicast traffic?
See the attached file
Daryl,
You need to remember that the counts you are seeing are cumulative.
These have been counting up since the last time to cleared the counters on
the interfaces.
You have not cleared the counters on the interface in question since the box
was last reloaded
Last clearing of "show Interface" counters never
Alex.
