Slow upload speed behind cisco router
Zeljko Popovic
       Hi All,
I have working internet behind cisco 2811 on all vlans however upload speed is very slow and ftp server download is slow and times out, previously when directly connected to modem/router was fine, anyone there to help? This is router config below:
Current configuration : 2229 bytes
! Last configuration change at 02:21:18 UTC Tue Mar 12 2013
version 15.1
hostname cfg-router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn FHK1419F3Y0
redundancy
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 190.0.0.11 255.255.0.0
ip nat inside
ip virtual-reassembly in
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 172.16.0.11 255.255.240.0
ip nat inside
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.100.11 255.255.255.0
ip nat inside
interface FastEthernet0/0.40
encapsulation dot1Q 40
ip address 192.168.200.11 255.255.255.0
ip nat inside
interface FastEthernet0/1
ip address 192.168.0.21 255.255.255.0
ip nat outside
duplex auto
speed auto
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/1 overload
ip nat inside source list 2 interface FastEthernet0/1 overload
ip nat inside source list 3 interface FastEthernet0/1 overload
ip nat inside source list 4 interface FastEthernet0/1 overload
ip nat inside source list 101 interface FastEthernet0/1 overload
ip nat inside source static tcp 190.0.0.10 21 interface FastEthernet0/1 21
ip nat inside source static tcp 190.0.0.10 3389 interface FastEthernet0/1 3389
ip route 0.0.0.0 0.0.0.0 192.168.0.1
access-list 1 permit 190.0.0.0 0.0.255.255
access-list 2 permit 172.16.0.0 0.0.15.255
access-list 3 permit 192.168.100.0 0.0.0.255
access-list 4 permit 192.168.200.0 0.0.0.255
access-list 101 permit ip any any
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
6 Replies 6
tobyarnett
You are likely getting your outside interface syncing up as half duplex due to your auto/auto config. Issue the
Show interface fa0/1
Check tho see what your duplex is coming up as. If it is half then hard code in a full duplex configuration.
Conf t
Into f0/1
Duplex full
End
You could also check your inside connection, but I think the outside link is likely your issue. Also check your logs for anything unusual.
Toby
Sent from Cisco Technical Support Android App
-Toby
Please don't forget to rate any helpful post.
_____________________________________
There are no great limits to growth because there are no limits of human intelligence, imagination, and wonder.
- Ronald Reagan
I set this up on duplex full, no change. For example when I ftp local address it is fast from one vlan to another however when I use outside address then very slow and drops out.
Hello Zeljko,
I do not know if this will help, but your NAT configuration is little bit "wild".
try this ->
no ip nat inside source list 1 interface FastEthernet0/1 overload
no ip nat inside source list 2 interface FastEthernet0/1 overload
no ip nat inside source list 3 interface FastEthernet0/1 overload
no ip nat inside source list 4 interface FastEthernet0/1 overload
no ip nat inside source list 101 interface FastEthernet0/1 overload
no access-list 1 permit 190.0.0.0 0.0.255.255
no access-list 2 permit 172.16.0.0 0.0.15.255
no access-list 3 permit 192.168.100.0 0.0.0.255
no access-list 4 permit 192.168.200.0 0.0.0.255
no access-list 101 permit ip any any
ip access extended NAT_ACL
permit ip 190.0.0.0 0.0.255.255 any
permit ip 172.16.0.0 0.15.255.255 any
permit ip 192.168.100.0 0.0.0.255 any
permit ip 192.168.200.0 0.0.0.255 any
deny ip any any
route-map NAT_MAP
match ip add NAT_ACL
ip nat inside source route-map NAT_MAP Fa0/1 overload
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Hi Grana,
Thanks for this however it performs as same as the one I had before, testing upload speed to internet, ftp and rd still 10 times slower then when not behind router.
What bandwidth does your link to internet have?
Towards what server are you testing it?
Can you perform this test?
Connect your laptop to router, to wan port Fa0/1 and configure laptop's interface with IP from this range 192.168.0.0/24.
And try now if connection from LAN is slow with some ftp file transfer.
If connection is still slow, it is caused definitely by router, if not we eliminated one point which could cause problems
Best Regards
Hi Blau grana
Actually I found where the problem was, a faulty cable from router was causing an issue, as soon as I changed it everything went flying 10 times faster. Anyone who is interested can use above Config as functional, both versions mine and yours amended. Thanks for making an interest in trying to fix it.
Kind regards
Zeljko
