Slow vlan
wharrison
I run a 6513 switch with floor flat vlans. three vlans icmp packet are normal 1 mm second, but one vlan packet are sometimes 80 mm seconds and above.
beth-martin
Level 10
Level 10
The symptoms of slow connectivity on a VLAN can be caused by multiple factors on different network layers. Commonly the network speed issue may be occurring on a lower level, but symptoms can be observed on a higher level as the problem masks itself under the term "slow VLAN". To clarify, this document defines the following new terms: "slow collision domain", "slow broadcast domain" (in other words, slow VLAN), and "slow interVLAN forwarding". Refer URL
http://cisco.com/en/US/tech/tk389/tk689/technologies_tech_note09186a00801f9eb3.shtml#common_causes
