SM-ES2-16-P module
abdulkarim041
Level 2
Level 2
I have Cisco 2911 router with  SM-ES2-16-P module. I am able to access it  with command" service-module gigabitEthernet 1/0 session" . output of sh ip int br
R1#sh ip int br
Embedded-Service-Engine0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/0 unassigned YES NVRAM up up
GigabitEthernet0/0.100 192.168.132.1 YES manual up up
GigabitEthernet0/0.102 142.102.64.254 YES NVRAM up up
GigabitEthernet0/0.202 142.202.64.254 YES NVRAM up up
ISM0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/1 172.16.10.1 YES NVRAM down down
GigabitEthernet0/2 100.100.100.1 YES NVRAM down down
ISM0/1 unassigned YES unset up up
GigabitEthernet1/0 192.168.195.10 YES manual up up
GigabitEthernet1/1 unassigned YES unset up up
issue is that I am unable to ping 192.168.195.10 from switch module. As per below mentioned link I should configure L3 interface in switch module.
http://www.cisco.com/c/en/us/support/docs/interfaces-modules/network-modules/82288-es-mod-config.html#step6
but i dont have the option of "no switchport" under any interface. Kindly let me know how I can resolve this issue.
BR
AbdulKarim
can you post the running config of your router, as well as the output of 'show version' ?
R1#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 06-Feb-15 17:29 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
R1 uptime is 4 days, 21 hours, 41 minutes
System returned to ROM by reload at 22:52:09 UTC Tue Feb 21 2017
System restarted at 22:54:11 UTC Tue Feb 21 2017
System image file is "flash0:c2900-universalk9-mz.SPA.154-3.M2.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 466944K/57344K bytes of memory.
Processor board ID FJC1923A2T0
6 Gigabit Ethernet interfaces
3 terminal lines
4 Voice FXS interfaces
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
Cisco Unity Express 8.6.6 in slot/sub-slot 0/0
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO2911/K9 FJC1923A2T0
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
NtwkEss None None None
CollabPro None None None
R1#
ip cef
no ipv6 cef
cts logging verbose
voice-card 0
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
license udi pid CISCO2911/K9 sn FJC1923A2T0
hw-module ism 0
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 1
redundancy
interface Loopback0
description *** HQ LO ***
ip address 142.1.64.254 255.255.255.0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.100
encapsulation dot1Q 100
ip address 192.168.132.1 255.255.255.0
interface GigabitEthernet0/0.102
encapsulation dot1Q 102
ip address 142.102.64.254 255.255.255.0
interface GigabitEthernet0/0.202
encapsulation dot1Q 202
ip address 142.202.64.254 255.255.255.0
interface ISM0/0
no ip address
shutdown
!Application: CUE Running on ISM
interface GigabitEthernet0/1
description ***SW-PSTN***
ip address 172.16.10.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
ip address 100.100.100.1 255.255.255.0
duplex auto
speed auto
interface ISM0/1
no ip address
interface GigabitEthernet1/0
ip address 192.168.195.10 255.255.255.0
interface GigabitEthernet1/1
switchport mode trunk
no ip address
interface Vlan1
no ip address
router ospf 1
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
shutdown
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 192.168.132.4 port 2000
max-ephones 5
max-dn 5
line con 0
privilege level 15
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
flowcontrol software
line 131
no exec
transport input all
stopbits 1
line vty 0 4
session-timeout 500
exec-timeout 500 0
privilege level 15
logging synchronous
no login
transport input all
line vty 5 15
session-timeout 500
exec-timeout 500 0
privilege level 15
logging synchronous
no login
transport input all
scheduler allocate 20000 1000
ntp source GigabitEthernet0/0.100
ntp master 5
ntp update-calendar
end
R1#
interface GigabitEthernet1/0 with IP address 192.168.195.10/24 connnects the router to the switch module. One of the interfaces on the ES module needs to be configured with an IP address from that same range, and then you need to set a default route on the ES, pointing to 192.168.195.10 as the next hop:
ip route 0.0.0.0 0.0.0.0 192.168.195.10
Let's say you want to configure 1/0/2 as the port communicating with R1, what options do you see ?
R1-ES#conf t
R1-ES(config)#interface GigabitEthernet1/0/2
R1-ES#(config-if)#?
also make sure that you are running at least 12.2(52)EX on the EtherSwitch...
