SM-ES3G-24-P Module with 2900 Router
Andrewkai
I'm trying to configure some switching here. I have 2900 Router(ios ver 15.0) and put SM Module in that router.
I would like to know how to configure that Module to work as a switch?
Very Much appreciate your help!
Sincerely,
Andrew
2 Accepted Solutions
Jon Marshall
Sincerely,
Andrew
Andrew
Use this configuration guide to get started -
http://www.cisco.com/en/US/customer/docs/routers/access/interfaces/software/feature/guide/eesm_sw.html#wp1919696
Jon
Hi Andrew,
Answer is given in step13:
Step 13
control+shift+6 x
Example:
Switch# control+shift+6 x
Returns you to the router console while keeping the console session to the switch
Keep pressing control+sift+6 and then press x key from key board
Or you can try ctrl+ccc (not sure whether this works or not)
Mahesh
Jon Marshall
Sincerely,
Andrew
Andrew
Jon
Hi Jon,
I followed that doc and I can access to the switch module using command #service module gi 1/0 session
Then I reached to switch#....
From there I can use like a switch to that module. But the problem is How to get out form the switch module.
I want to go back to router login page.
Please advise.. Thanks for your help.
Sincerely,
Andrew
Hi Andrew,
Step 13
control+shift+6 x
Example:
Mahesh
Big thanks Mahesh! I can get out form there.
I used ctrl+shift+6+ X and clear the line 1/0 as follow
switch# press ctrl shift 6 x
Router#sh session
          #Clear line 1/0
Cheer!
Andrew
