Problem cisco 2950 and LinkSys SRW 2024 Switch
habib_azhar
Problem in Network switches 2950 series, which was connected to SRW 2024 Gigabit switches, a problem was in 2920 10/100 switches , a uplink port's power off, when switch was restarted then, uplink port working normally, but suddenly after half / an hour, uplink port down again, so please help, and what is best solution of network switches configuration. because switches was not configured or managed, just simply switches was connected through Crosse cable one by one,
thanks for your early response
andtoth
Level 4
Level 4
Can you paste some of the error messages from 'show logging' or Syslog server you've received on the Cisco switches when the uplink port went down?
Is it a new setup or was it working before?
Did you change anything in your network or configuration?
Andras
2950 is old setup, but SRW 2024 new switches, changes only connected only new switches, when i connected another port that port off too, but please tell me how can i manage Network switches ?
