small issue
Mahson
Visitor
i have problem on switch 3850 i tried to do recovery password on rommon mode but after the system boot it shows me the username and password so what can i do ?
this is the commands
switch>flash_init
switch>SWITCH_IGNORE_STARTUP_CFG=1
switch>boot flash:packages.conf
pieterh
maybe you also need the second variable
Add the following variables.
     Switch: SWITCH_IGNORE_STARTUP_CFG=1
     Switch: SWITCH_DISABLE_PASSWORD_RECOVERY=0
Then boot the switch.
     Switch: boot
When i put SWITCH_DISABLE_PASSWORD_RECOVERY=0 they shows me this variable can’t be change just read only
ignore the 'read only' error message and boot the switch anyway:
Switch: SWITCH_DISABLE_PASSWORD_RECOVERY=0  --> ignore 'Read Only' message
Switch: BOOT=flash:packages.conf
Switch: boot
