12-07-2019 09:17 AM
Dear Experts, I have configured 3 VLANs on 3750 switch. VLAN 5,100,200 respectively. VLAN 5 is connected to internet.VLAN 200 for clients.
Added route to internet 0.0.0.0 0.0.0.0 192.168.1.1
C 192.168.1.0/24 is directly connected, Vlan5
S* 0.0.0.0/0 [1/0] via 192.168.1.1
But not able to ping to 192.168.1.1 from other VLANs
I have attached the result of
Ping from VLAN 5,100 and 200
Show run config, sh ip route, sh ip int br,sh vlan brief, #sh sdm prefer and #sh vtp status.
Thanks in advance....
Solved! Go to Solution.
12-07-2019 10:11 AM
Hi!
Do you have access to the device behind the IP 192.168.1.1?
Can we check the routes on this device? It may does not have any routes to get back to the Cat3750.
Let me know.
Best regards
Julian
12-07-2019 10:07 AM
as per your output these interfaces are down, make sure your interface participate on that VLAN have an active device, so the SVI will come up and you able to ping.
Vlan100 10.10.100.1 YES manual up down
Vlan200 172.20.0.1 YES manual up down
12-07-2019 11:23 AM
Thanks for support.
I connected my laptop to port gig 1/015 and protocol UP.
PC got IP from dhcp ( Vlan 200) and able to ping to gateway 172.20.0.1. But it was not route to Default Gateway configured in switch
12-07-2019 10:11 AM
Hi!
Let me know.
Best regards
Julian
12-07-2019 11:28 AM
This is the Topology I am trying to apply. This L3 switch is connected to a ADSL modem for testing.
12-07-2019 09:06 PM
