%SMART_LIC-3-COMM_FAILED: Communications failure with the Cisco Smart
Deepak Kumar
I am busy with a network migration project and activating licenses on the Cisco C9500 XE17.6.5 using the On-Prem Licensing server (Cisco Smart Software Manager On-Prem) and getting some strange issue as:
Apr 25 10:05:19 UTC: CALL-HOME-SL-TRACE: smart_license_req_http_send[156], Sending smart license request to url list "https://10.xx.x.xxx:443/Transportgateway/services/DeviceRequestHandler"
Apr 25 10:05:19 UTC: CALL-HOME-SL-TRACE: smart_license_req_http_send[162], Successfully send out http request.Apr 25 10:05:19 UTC: CALL-HOME-SL-TRACE: smart_license_resp_handle[182], SCH backend response info, len 0, max size 550
Apr 25 10:05:19 UTC: CALL-HOME-SL-TRACE: call_home_smart_license_stats_update[629], Update smart license stats entry, subtype REGISTRATION,stats_type 2
Apr 25 10:05:19 UTC: %SMART_LIC-3-COMM_FAILED: Communications failure with the Cisco Smart Software Manager (CSSM) : Fail to parse response data from SCH server.
I have reachability and other access switches are able to connect successfully (not the same IOS version).
CSSM version: 8-202010
Have you faced the same issue ever? Do we have any kind of IOS version compatibility issue or any known bug with CSSM?
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Leo Laohoo
Put in a logging discriminator to ignore it.
Dear @Leo Laohoo Switch is not reporting the use report to the CSSM. It is not about the logs, it is about the issue.
Deepak Kumar,
