Smart license questions
raj-toor
I am new to smart licensing.  So i have registered these switches 9500 switches. But I have few questions
What if they loose communication to cloud, would the device fall back to eval?
If it fallbacks's to eval/expires, do we get a notification of any sort?
What happens to the features if eval too gets expired? We got the advantage license for the feature it supports, specifically bgp/mpls.
SW1#show license status
Smart Licensing is ENABLED
Utility:
  Status: DISABLED
Data Privacy:
  Sending Hostname: yes
    Callhome hostname privacy: DISABLED
    Smart Licensing hostname privacy: DISABLED
  Version privacy: DISABLED
Transport:
  Type: Callhome
Registration:
  Status: REGISTERED
  Smart Account: ######
  Virtual Account: DEFAULT
  Export-Controlled Functionality: ALLOWED
  Initial Registration: SUCCEEDED on Jul 12 09:43:57 2019 PDT
  Last Renewal Attempt: None
  Next Renewal Attempt: Jan 08 09:43:57 2020 PDT
  Registration Expires: Jul 11 09:38:53 2020 PDT
License Authorization:
  Status: AUTHORIZED on Jul 12 09:44:01 2019 PDT
  Last Communication Attempt: SUCCEEDED on Jul 12 09:44:01 2019 PDT
  Next Communication Attempt: Aug 11 09:44:01 2019 PDT
  Communication Deadline: Oct 10 09:39:00 2019 PDT
Export Authorization Key:
  Features Authorized:
    <none>
  C9500-DNA-16X-A         (C9500-16X DNA Advantage)         2 AUTHORIZED
  C9500 Network Advantage (C9500 Network Advantage)         2 AUTHORIZED
Reza Sharifi
Have a look. The license does not require daily Internet access. You can also set a locally on a server that has Internet access if your switch will not have access to Internet.
https://blogs.cisco.com/enterprise/cisco-smart-software-licensing
