2960XR IP SLA and Tracking
collinsjl
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E3, RELEASE SOFTWARE (fc3)
Trying to accomplish the following on a 2960XR
Takes this command:
track 10 ip sla 11 reachability
ip route 10.200.250.0 255.255.255.0 10.1.10.1 track 10
But will not take this:
ip sla 11
icmp-echo 10.1.10.2
ip sla schedule 11 start-time now
Just want to install a static tracked route that goes away when the distant end is not available so it will use the default route to the firewall so it will go to the site to site as a backup.
All that is available is:
2960XR(config)#ip sla ?
key-chain       Use MD5 Authentication for IP SLAs Control Messages
responder       IP SLAs Responder
Any help?  Very frustrated with the 2960XR.  Keep running into limitations.  EIGRP Stub..grrrr
6 Replies 6
Mark Malone
sounds like license issues
whats your license your running on the switch , is it ip lite or lan lite ?
Sorry about the delay in response.  The 2960XR only comes in IP Lite
Hi ,
Could you resolve this issue? i have the same.
regards
Thanks Georg for quick response !
I would like to use IP SLA to track static routes (HA), from documentation I see that 2960XR supports only IP SLA responder mode. Is there any other way to achieve object tracking on 2960XR  (15.2(4)E8) ?
regards
try and downgrade to 15.0.2-EX3. I am not sure it is in there, at some point they took the feature out...
https://software.cisco.com/download/home/284832158/type/280805680/release/15.0.2-EX3
