smart serial connection not working between 2600 series routers
breynold76
I have a smart serial cable connected between R2 and R3 and it is up/down. I have tried switching the dce to the other router but nothing. when I type no shut it comes up/up for about 20-30 seconds then goes to up/down. Tested 3 different cables both ends. The R1 to R2 connection came right up when connected. I am not sure if I have a bad wic card or something in the config. Any help with this would be greatly appreciated.
R3#show controllers se0/1
Interface Serial0/1
Hardware is PowerQUICC MPC860
DCE V.35, clock rate 56000
idb at 0x82C19B18, driver data structure at 0x82C1C4EC
SCC Registers:
General [GSMR]=0x2:0x00000030, Protocol-specific [PSMR]=0x8
Events [SCCE]=0x0000, Mask [SCCM]=0x001F, Status [SCCS]=0x03
Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E
Interrupt Registers:
Config [CICR]=0x00367F80, Pending [CIPR]=0x00000200
Mask   [CIMR]=0x30200440, In-srv  [CISR]=0x00000000
Command register [CR]=0x680
Port A [PADIR]=0x4400, [PAPAR]=0xFFFF
       [PAODR]=0x0000, [PADAT]=0x9BDF
Port B [PBDIR]=0x0630F, [PBPAR]=0x0000E
       [PBODR]=0x00000, [PBDAT]=0x39CED
Port C [PCDIR]=0x00C, [PCPAR]=0x000
       [PCSO]=0x280,  [PCDAT]=0xCF2, [PCINT]=0x00F
Receive Ring
        rmd(68012930): status 9000 length 60C address 3C6CDC4
        rmd(68012938): status B000 length 60C address 3C6C744
Transmit Ring
        tmd(680129F0): status 5C00 length 18 address 3C00354
R2#show controllers se0/0
Interface Serial0/0
DTE V.35 clocks stopped.
idb at 0x80F93B58, driver data structure at 0x80F966F0
SCC Registers:
Events [SCCE]=0x0000, Mask [SCCM]=0x001F, Status [SCCS]=0x02
Config [CICR]=0x00367F80, Pending [CIPR]=0x00000A00
Command register [CR]=0x640
Port A [PADIR]=0x4000, [PAPAR]=0xFFFF
       [PAODR]=0x0000, [PADAT]=0xF9EB
Port B [PBDIR]=0x0630F, [PBPAR]=0x0900E
       [PBODR]=0x0000E, [PBDAT]=0x30CCD
       [PCSO]=0x280,  [PCDAT]=0xC30, [PCINT]=0x00F
Receive Ring
        rmd(68012930): status 9000 length 60C address 1C93EA4
        rmd(68012938): status B000 length 60C address 1C94524
Transmit Ring
        tmd(680129B0): status DC00 length 18 address 1D80654
R2(config-if)#shut
R2(config-if)#no shut
R2(config-if)#
16:23:59: %LINK-5-CHANGED: Interface Serial0/0, changed state to administratively down
R2(config-if)#
16:24:02: %LINK-3-UPDOWN: Interface Serial0/0, changed state to up
16:24:03: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0, changed state to up
R2(config-if)#
16:24:28: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0, changed state to down
Richard Burts
When I see a problem with serial interfaces being up/down frequently one of my first thoughts is to wonder about whether clock has been specified. I am glad to see the output of show controller does indicate that one router is DCE with a clock rate. So this is not the problem. Perhaps you could also post the configuration from both routers?
Rick
Rick
R2#show run
Building configuration...
Current configuration : 599 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname R2
ip subnet-zero
interface FastEthernet0/0
ip address 192.168.2.1 255.255.255.128
speed 100
full-duplex
interface Serial0/0
ip address 10.1.1.2 255.255.255.252
interface Serial0/1
ip address 10.1.1.5 255.255.255.252
clockrate 125000
ip classless
ip http server
ip pim bidir-enable
line con 0
exec-timeout 0 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 0 0
password cisco
logging synchronous
login
end
R3#show run
Current configuration : 760 bytes
version 12.3
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
ip address 192.168.2.129 255.255.255.128
speed 100
full-duplex
interface Serial0/0
no ip address
interface FastEthernet0/1
no ip address
speed 100
full-duplex
interface Serial0/1
ip address 10.1.1.1 255.255.255.252
clock rate 56000
ip http server
no ip http secure-server
ip classless
line con 0
exec-timeout 0 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
password cisco
login
end
Al though this is default, but under each interface can you add:
encap hdlc
also, on R2,
Interface Serial0/0
So, since r1 and r2 are working fine, can you check the show controller and see if you see the same message on DTE router?
As requesed i added encap hdlc to both sides. There is a difference on the dte end on R1.
R2#show controllers se0/1
Interface Serial0/1
DCE V.35, clock rate 125000
idb at 0x80F97F3C, driver data structure at 0x80F9ACB0
SCC Registers:
Events [SCCE]=0x0000, Mask [SCCM]=0x001F, Status [SCCS]=0x06
       [PAODR]=0x0000, [PADAT]=0xF9FF
Receive Ring
        rmd(68012A30): status 9000 length 1A address 1D7FE44
        rmd(68012A38): status B000 length 1A address 1D7F144
Transmit Ring
        tmd(68012AB0): status 5C00 length 18 address 1D80654
R1#show controllers se0/0
Interface Serial0/0
DTE V.35 TX and RX clocks detected.
idb at 0x81F76008, driver data structure at 0x81F7899C
SCC Registers:
Config [CICR]=0x00367F80, Pending [CIPR]=0x00000800
Mask   [CIMR]=0x20200400, In-srv  [CISR]=0x00000000
       [PAODR]=0x0000, [PADAT]=0xFFF3
Port B [PBDIR]=0x0630F, [PBPAR]=0x0400E
       [PBODR]=0x0000E, [PBDAT]=0x3DDDD
       [PCSO]=0x380,  [PCDAT]=0xF30, [PCINT]=0x00F
Receive Ring
        rmd(680127F0): status 9000 length 2E address 2DB4FC4
        rmd(680127F8): status B000 length 30 address 2DB5644
Transmit Ring
        tmd(680128B0): status 5C00 length 2F address 2DDE8F4
--More--
