%SNMP-3-INPUT_QFULL_ERR: Packet dropped due to input
Asim Afzal
HI,
I am getting error message on my 6509 switch console when i try to add the device in my cisco LMS server
Below is snmp config
snmp-server view public-view iso included
snmp-server view public-view ciscoMemoryPoolMIB excluded
snmp-server community xxxxx RW
snmp-server host 172.16.1.100 version 2c xxxxx
snmp-server enable trap
Below is debug snmp output
KFH-DR-CORE-SW1#
6w1d: SNMP: Packet received via UDP from 172.16.1.100 on Vlan2
Oct  6 07:57:25: %SNMP-3-INPUT_QFULL_ERR: Packet dropped due to input
queue full
KFH-DR-CORE-SW1#
6w1d: SNMP: Queuing packet to 172.16.1.100
6w1d: SNMP: V2 Trap, reqid 309, errstat 0, erridx 0
sysUpTime.0 = 378818380
snmpTrapOID.0 = ciscoSyslogMIB.2.0.1
clogHistoryEntry.2.189825 = SNMP
clogHistoryEntry.3.189825 = 4
clogHistoryEntry.4.189825 = INPUT_QFULL_ERR
clogHistoryEntry.5.189825 = Packet dropped due to input
clogHistoryEntry.6.189825 = 378818380
6w1d: SNMP: Packet sent via UDP to 172.16.1.100
KFH-DR-CORE-SW1#
Oct  6 07:57:35: %SNMP-3-INPUT_QFULL_ERR: Packet dropped due to input
queue full
KFH-DR-CORE-SW1#
6w1d: SNMP: V2 Trap, reqid 310, errstat 0, erridx 0
sysUpTime.0 = 378819380
clogHistoryEntry.2.189826 = SNMP
clogHistoryEntry.3.189826 = 4
clogHistoryEntry.4.189826 = INPUT_QFULL_ERR
clogHistoryEntry.5.189826 = Packet dropped due to input
clogHistoryEntry.6.189826 = 378819380
KFH-DR-CORE-SW1#
6w1d: SNMP: Packet received via UDP from 127.0.0.91 on EOBC0/0
Oct  6 07:57:51: %SNMP-3-INPUT_QFULL_ERR: Packet dropped due to input
queue full
KFH-DR-CORE-SW1#
6w1d: SNMP: V2 Trap, reqid 311, errstat 0, erridx 0
sysUpTime.0 = 378820925
clogHistoryEntry.2.189827 = SNMP
clogHistoryEntry.3.189827 = 4
clogHistoryEntry.4.189827 = INPUT_QFULL_ERR
clogHistoryEntry.5.189827 = Packet dropped due to input
clogHistoryEntry.6.189827 = 378820924
KFH-DR-CORE-SW1#
Oct  6 07:57:53: %SNMP-3-INPUT_QFULL_ERR: Packet dropped due to input
queue full
KFH-DR-CORE-SW1#
6w1d: SNMP: V2 Trap, reqid 312, errstat 0, erridx 0
sysUpTime.0 = 378821125
clogHistoryEntry.2.189828 = SNMP
clogHistoryEntry.3.189828 = 4
clogHistoryEntry.4.189828 = INPUT_QFULL_ERR
clogHistoryEntry.5.189828 = Packet dropped due to input
clogHistoryEntry.6.189828 = 378821124
KFH-DR-CORE-SW1#
Oct  6 07:57:55: %SNMP-3-INPUT_QFULL_ERR: Packet dropped due to input
queue full
KFH-DR-CORE-SW1#
6w1d: SNMP: V2 Trap, reqid 313, errstat 0, erridx 0
sysUpTime.0 = 378821381
clogHistoryEntry.2.189829 = SNMP
clogHistoryEntry.3.189829 = 4
clogHistoryEntry.4.189829 = INPUT_QFULL_ERR
clogHistoryEntry.5.189829 = Packet dropped due to input
clogHistoryEntry.6.189829 = 378821380
KFH-DR-CORE-SW1#
Oct  6 07:58:51: %SNMP-3-INPUT_QFULL_ERR: Packet dropped due to input
queue full
KFH-DR-CORE-SW1#
6w1d: SNMP: V2 Trap, reqid 314, errstat 0, erridx 0
sysUpTime.0 = 378826924
clogHistoryEntry.2.189830 = SNMP
clogHistoryEntry.3.189830 = 4
clogHistoryEntry.4.189830 = INPUT_QFULL_ERR
clogHistoryEntry.5.189830 = Packet dropped due to input
clogHistoryEntry.6.189830 = 378826924
KFH-DR-CORE-SW1#
Oct  6 07:58:53: %SNMP-3-INPUT_QFULL_ERR: Packet dropped due to input
queue full
KFH-DR-CORE-SW1#
6w1d: SNMP: V2 Trap, reqid 315, errstat 0, erridx 0
sysUpTime.0 = 378827124
clogHistoryEntry.2.189831 = SNMP
clogHistoryEntry.3.189831 = 4
clogHistoryEntry.4.189831 = INPUT_QFULL_ERR
clogHistoryEntry.5.189831 = Packet dropped due to input
clogHistoryEntry.6.189831 = 378827124
Rolf Fischer
Level 9
Level 9
this looks like the workaround described in CSCsk27147.
Should be resolved in 12.2(33)SXI.
What IOS are you using?
Rolf
HI,
I am using
122-33.SXH8b
Salam Asim,
Few bugs and it is recorded on csc thread;
CSCsm80154    SNMP stops responding due to %SNMP-3-INPUT_QFULL_ERR
CSCto74586    SNMP - SNMP-3-INPUT_QFULL_ERR when using CISCO-ENERGYWISE-MIB
CSCti48279    %SNMP-3-INPUT_QFULL_ERR needs improvement
CSCth71681    SNMP-3-INPUT_QFULL_ERR, IPCTXERR, and/or CLC unresponsive in SCB
CSCsg60274    Snmp Engine stops responding - Error %SNMP-3-INPUT_QFULL_ERR
CSCtq48275    %SNMP-3-INPUT_QFULL_ERR generated after OIR operations
CSCtn19200    Catalyst6500 generate SNMP-3-INPUT_QFULL_ERR when receive IF-MIB.
What i mean from a genuine issue is when this error in syslog is just a symptom of other issue, like high CPU, device polled extensively or snmp engine not responding at all, etc.
The first thing to try to t/s this is to stop and start snmp engine:
To stop:
no snmp-server
To start:
Any snmp related command which was already configured before stopping snmp engine. You can see snmp configuration using show run | incl snmp-server.
If that does not fix the issue, next step is to take the traceback for SNMP ENGINE PID which i mentioned on last post. traceback can reveal any issue with snmp process.
Ref:https://supportforums.cisco.com/thread/2166321
Inayath
*Plz dont forget to rate the usefull posts.
