Ping reply issue
jeevak mukadam
Level 3
Level 3
I am facing this from ong time.Please check attached file for reference.I am pinging from local machine to access switch where i am getting ping reply more that 1ms.Then to second hop also i am getting some delay.
i have also check traffic on all trunk link but still response is same.
I think i should get reply equal to 1ms in local lan.
Need expert advise on this
8 Replies 8
Sandeep Choudhary
HI Jeevak,
Can you please check your local machine NIC settings.
go to run> type devmgmt.msc then go to NIC>Configuration>Advanced. Click Speed and Duplex
Both side it should be speed 100, duplex full.
Please also check the port of the swicth where your machine is connected, it should also the same setting on port.
Speed 100
Duplex full.
Hope it helps.
Hello Sandeep,
Thanks for your reply,
My switch end is auto speed and duplex mode.Speed between pc and switch is 1gbps.
Can you paste the output from your switch of this command:
sh int XXX (Where your pc is connected).
@ sandeep
GigabitEthernet4/0/5 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is d0c2.829f.9805 (bia d0c2.829f.9805)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 20:25:52, output 00:00:18, output hang never
  Last clearing of "show interface" counters 21:19:55
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 97661
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 10000 bits/sec, 6 packets/sec
  5 minute output rate 133000 bits/sec, 159 packets/sec
     237192 packets input, 45850775 bytes, 0 no buffer
     Received 3616 broadcasts (1218 multicasts)
     1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 1218 multicast, 0 pause input
     2004530 packets output, 304690608 bytes, 0 underruns
I recommend clearing the interface counters and then observing the number of drops over the next hour
can you do : clear counter GigabitEthernet4/0/5
chane the speed and duplex setting and then check it.
Output drops typically indicate a congested interface.  This can  occur when going from a high speed interface (such as the SW B to SW C  link at 1000Mbps) to a lower speed link (SW A to SW B at 100Mbps).
Output  drops are not all bad, as the drops indicate the flow control  mechanisms of the upper layer protocols are working to decrease the TCP  window size.  Also, if the drops are due to a constant high-rate flow of  traffic you cannot prevent them, but you can control them.
@ Sandeep,
All PCs which are 3 hop away for that i am getting perfect 1ms reply
Ok then we will start troubleshooting from swicth :
Can you show the output of all the interface between these devices.
PC--------???>Access Switch ??------------???>  Core switch
Command should be : sh int Interface
Can you post the "sh interface " and "sh controller e "?
Wilson Bonilla
Level 8
Level 8
Hello
Remember that ICMP traffic for a switch CPU is lower priority packet, that is not a good way to measure performance or availability in your switches. Having said that once the switch sees the echo request it will process it at software or at hardware, and remember switches do everything at hardware / hard-wired speed.
If you want really to measure speed then, ping from one host to another host across the switches that will give you more accurate information, if you are still concern about it then, take a capture rx in the ingress and tx at the egress port, so that you can check timestamps how long did the packet take to enter and exit the switch.
Regards.
Wilson B.
