SNMP agent not responding
gauravpundir231
Level 2
Level 2
Hi All,
We intermittently receives alerts like SNMP agent is not responding.
Can anybody pls share troubleshooting/validation steps that can be done from network side (commands on Cisco Switch and Router) not from snmp server side.
DC Broderick
Frequent Visitor
Frequent Visitor
Can you post the SNMP section from your running-config?  That would help in answering your question.
Mark Elsen
 - Could be a bug , check software version on your device, use a recent release if applicable.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Reza Sharifi
You can use the "snmp get" command to poll the device if you know the IP and an OID, but you have to enable "snmp-server manager" first.
