SNMP and Source interface
a.yazdani
Community Member
Is there a way to lockdown SNMP traffic so that it only transmits on a  VLAN ?
I have catalyst 3750g with ten VLAN interfaces that have IP address from different subnet and SNMP Configured . when I try to discover switch with all subnet , it shows me the switch per each interface , Is there a way to limit this traffic to a VLAN , so just show me once !
thanks
Reza Sharifi
This maybe a function in your monitoring system.  You system is discovering all 10 vlans on your switch and there maybe a way you can uncheck the other 9 vlans, so they don't get discovered.
Thanks Reza , I will work on it .
