SNMP authentication trap and syslog command
sam-lee
Level 3
Level 3
I am trying to configure Cisco switch to send Trap and Syslog to NMS.
What command i should use to enable these?
Thanks!
Kostas Kyriakos
Level 3
Level 3
Hello.
Please try the following for starters:
! Define a ReadOnly Community
snmp-server community RO
! Define an IP Interface, sourcing the traps. Make sure you verify ip connectivity to the NMS Server, from this interface.
snmp-server trap-source
! Define the NMS Server IP
snmp-server host
! Try this sample trap configuration
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
You can define additional traps with the command:
snmp-server enable traps ?
Hope this helps.
How about syslog? What needs to be configured
for authnetication failure or link down to be send via syslog? What's the cmd? Thanks!!
Syslog can be configured by using the following
logging x.x.x.x
You can set the logging level of the traps that get sent ot the NMS using the:
logging trap [level] command.
Hope this helps,
Jonathan
