SNMP Comunitys R or R/W
ciscolover
Hi all,
I'm going to install an SNMP server(NAGIOS) in the next days.
The network that I administrer it's a small/medium network.
I'm not sure if it's a good idea to configure SNMPv2 with communitys with Read Write privilege in the switches.Maybe it's not good idea and i'ts better to configure only Read communitys. I want to listen your opinion about this.
¿It's a good idea or its a dangerous idea? Can anyone tell me the benefits and inconveniences about the use of Read/write communitys?
Thanks all and sorry for my bad english
JohnTylerPearce
Level 7
Level 7
This depends on  what you want the NMS(Network Management Server) server to do,
For example, at my current place of work we have Solarwinds Orion, I have configured read and write community strings
With my write community string, I can configure a switch through Orion and have it pushed to the switch. Whereas if I had
just read, I could just get SNMP traps, read configuration information etc etc.
So it really depends on what you want to do.
milan.kulik
Level 10
Level 10
AFAIK, Nagios does not need Write access to your devices at all.
You can call me paranoid but I would never give any SW write access to devices I'm responsible for (unless absolutely necessary).
And IMHO, it's also a good idea to configure an ACL which filters source IP addresses permitted to get Read access to your devices - to prevent possible DoS attack by some "advanced" user just playing with snmpwalk command or some SNMP tool.
And use non-default community strings, of course!
BR,
Milan
